Architecture
The high-level architecture is shown below. All of the client interactions with Audio Weaver are through TinyALSA (for real-time audio) and TinyMix (for control) plugins. Internally, Audio Weaver communicates with the plugins through shared memory and IPCC signaling. Additionally, there are configuration files generated through the Audio Weaver Target Configuration (awe-tc) application. One of the configuration files is used to configure the audio processing cores and contains information such as heap sizes and number of threads. There is a second configuration file containing tuning symbols, data types, and variable ranges.
Audio I/O
Audio I/O is configured using modules in the Audio Weaver signal flow. There are currently modules for:
  • TDM serial port I/O
  • ALSA audio from the HLOS
In the future, this will be extended to include
  • USB audio I/O
  • Ethernet AVB
Audio Processors
The integration includes access to all audio processing cores in the SOC. For the Gen 4 SOC SA8255, this includes:
  • 0- ADSP
  • 1- GPDSP0
  • 2- GPDSP1
  • 3- Arm
Each of these DSPs is a single core Hexagon (ADSP has 4 threads; GPDSPs have 6 threads). For the Gen 5 SA8397 / SA8797 SOC, this includes:
  • 0- DSP0
  • 1- DSP1
  • 2- DSP2
  • 3- Arm
Each Gen 5 DSP has dual Hexagon cores with 12 threads. Qualcomm will offer performance levels of the Gen 5 silicon which expose 1, 2, or 3 DSPs. Only the highest performance tier has 3 dual core DSPs.
In all cases, the Arm library is able to extend processing across all Arm cores using the scheduling capabilities of the operating system. Thus, only a single instance of the Audio Weaver Arm library is needed and it is able to leverage all of the Arm cores. The cores will be ordered as shown above in the BSP code. (Putting the Arm at the end provides consistency between the Gen4 and Gen5 processor families.)
Clock Configuration
The system configuration file contains the default processor speed settings for the audio processors. When the system boots, the Hexagon DSPs are set to the speed listed in the configuration file. The Arm processor speed is not changed.
The SnapdragonClockSetting module can be used to adjust the processor speed and DDR memory speed of the Hexagon DSPs at run-time (in R4.0). In R4.1, this will change to the SnapdragonClockVoting module. These are the default clock speeds provided in the release:
SA8255
Processor
Default Speed
Max Speed
ADSP
1.344 GHz
1.344 GHz
GPDSP0
1.708 GHz
1.708 GHz
GPDSP1
1.708 GHz
1.708 GHz
Arm
2.1 GHz
2.1 GHz.
SA8797
DSP0
TBD
DSP1
TBD
DSP2
TBD
Arm
TBD
Audio Processor Local Memory
Audio Weaver defines 4 memory heaps that are available to the audio modules. The first 3 heaps are private to each audio processing core
  1. Fast
  2. FastB
  3. Slow
The 4th heap enables communication and synchronization between cores:
  1. Shared
The sizes of these heaps are defined in the startup XML initialization file and can be increased / decreased by the user without recompilation. The first 3 heaps (Fast, FastB, and Slow) are allocated from DDR. The Shared heap comes from carved out DDR memory. Memory for the Arm instance is dynamically allocated using malloc(). The tables below summarize the default heap sizes in the base distributions:
SA8255
Processor
Fast
Fast B
Slow
Shared
ADSP
250 kword
250 kword
250 kword
262 kword
GPDSP0
250 kword
250 kword
250 kword
262 kword
GPDSP1
250 kword
250 kword
250 kword
262 kword
Arm
4 Mword
2 Mword
1 Mword
262 kword
SA8397 / SA8797
Processor
Fast
Fast B
Slow
Shared
DSP0
0.5 MB (TCM)
1 MB (DDR)
1 MB (DDR)
TBD
DSP1
0.5 MB (TCM)
1 MB (DDR)
1 MB (DDR)
TBD
DSP2
0.5 MB (TCM)
1 MB (DDR)
1 MB (DDR)
TBD
Arm
4 MB (DDR)
4 MB (DDR)
4 MB (DDR)
TBD
