Danville_DAC_Filter
DAC Filter Control
This module controls the DAC Post Filters implemented in the target hardware. Please refer to the accompanying documentation of the target hardware Note that if user selects an unsupported value, target will use default value instead. The default value field gives users to enter a one time initialization value for this module instance. Clicking the overrride checkbox allows user to use a value entered via inspector.
typedef struct _ModuleDanville_DAC_Filter
INT32 DAC_Filter_Val; // DAC Filter Value
INT32 DAC_Filter_Default_Val; // DAC Filter Default Value
INT32 DAC_Filter_OLD_Val; // DAC OLD Filter Value
INT32 DAC_Filter_Override; // DAC Filter Override
} ModuleDanville_DAC_FilterClass;
DAC_Filter_Val | int | parameter | 0 | 0 | 0:15 | |
DAC_Filter_Default_Val | int | parameter | 0 | 0 | 0:15 | |
DAC_Filter_OLD_Val | int | parameter | 0 | 0 | 0:15 | |
DAC_Filter_Override | int | parameter | 0 | 0 | 0:1 |
File Name: Danville_DAC_Filter.m
M=Danville_Source_Select_module(NAME, HASINPUTPIN)
Author: E. Enrique
$Revision: 1.1 $
