Danville_Digital_Out
Digital Output Control
This module takes a value from the Audio Weaver Canvass and sends it to the target hardware Please refer to the accompanying documentation of the target hardware Locator values serves as an ID which associates the module instance to the hardware feature or connection The default value field gives users to enter a one time initialization value for this module instance. Clicking the overrride checkbox allows user to use a value via the inspector while the value from the canvass is ignored.
typedef struct _ModuleDanville_Digital_Out
INT32 Digital_Out_Val; // Digital Out Value
INT32 Digital_Out_OLD_Val; // Digital Out OLD Value
INT32 Digital_Out_Default_Val; // Digital Out Default Locator
INT32 Digital_Out_Locator; // Digital Out Locator
INT32 Digital_Out_Override; // Digital Out Override
} ModuleDanville_Digital_OutClass;
Digital_Out_Val | int | parameter | 0 | 0 | 0:65535 | |
Digital_Out_OLD_Val | int | parameter | 0 | 0 | 0:65535 | |
Digital_Out_Default_Val | int | parameter | 0 | 0 | 0:65535 | |
Digital_Out_Locator | int | parameter | 0 | 0 | 0:31 | |
Digital_Out_Override | int | parameter | 0 | 0 | 0:1 |
Description: Danville Output Value
Data type: int
Channel range: 1
Block size range: 1
File Name: Danville_Digital_Out.m
Author: E. Enrique
$Revision: 1.1 $
