Danville_DAC_Mute
DAC Mute Control
DAC Mute control.
typedef struct _ModuleDanville_DAC_Mute
    INT32 DAC_Mute_Val;                           // DAC Mute Value
    INT32 DAC_Mute_Default_Val;                   // DAC Mute Default Value
    INT32 DAC_Mute_OLD_Val;                       // DAC Mute Old Value
    INT32 DAC_Mute_Override;                      // DAC Mute Override
} ModuleDanville_DAC_MuteClass;
Name
Type
Usage
isHidden
Default value
Range
Units
DAC_Mute_Val
int
parameter
0:1
int
parameter
0:1
DAC_Mute_OLD_Val
int
parameter
0:1
DAC_Mute_Override
int
parameter
0:1
Description: DAC Mute Value
Data type: int
Channel range: 1
Block size range: 1
File Name: Danville_DAC_Mute.m
 M=Danville_DAC_Mute_module(NAME, HASINPUTPIN)
    NAME - name of the module.
 Copyright 2016.  Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
 $Revision: 1.1 $
 AudioWeaverModule [This tag makes it appear under awe_help]
