Danville_DAC_Volume_Mapping
DAC Volume Mapping Control
This module allows users to setup a grouping of channels that will be volume controlled as a set. The Danville DAC Volume module will use the grouping information when it changes volume. There are four available groupings.
typedef struct _ModuleDanville_DAC_Volume_Mapping
    INT32 Mapping_Saved;                          // DAC Volume Mapping Lock State Value
    INT32 GRP1_Sel_1;                             // DAC Volume Group 1 Select 1 Value
    INT32 GRP1_Sel_2;                             // DAC Volume Group 1 Select 2 Value
    INT32 GRP1_Sel_3;                             // DAC Volume Group 1 Select 3 Value
    INT32 GRP1_Sel_4;                             // DAC Volume Group 1 Select 4 Value
    INT32 GRP1_Sel_5;                             // DAC Volume Group 1 Select 5 Value
    INT32 GRP1_Sel_6;                             // DAC Volume Group 1 Select 6 Value
    INT32 GRP1_Sel_7;                             // DAC Volume Group 1 Select 7 Value
    INT32 GRP1_Sel_8;                             // DAC Volume Group 1 Select 8 Value
    INT32 GRP1_Sel_9;                             // DAC Volume Group 1 Select 9 Value
    INT32 GRP1_Sel_10;                            // DAC Volume Group 1 Select 10 Value
    INT32 GRP1_Sel_11;                            // DAC Volume Group 1 Select 11 Value
    INT32 GRP1_Sel_12;                            // DAC Volume Group 1 Select 12 Value
    INT32 GRP1_Sel_13;                            // DAC Volume Group 1 Select 13 Value
    INT32 GRP1_Sel_14;                            // DAC Volume Group 1 Select 14 Value
    INT32 GRP1_Sel_15;                            // DAC Volume Group 1 Select 15 Value
    INT32 GRP1_Sel_16;                            // DAC Volume Group 1 Select 16 Value
    INT32 GRP2_Sel_1;                             // DAC Volume Group 2 Select 1 Value
    INT32 GRP2_Sel_2;                             // DAC Volume Group 2 Select 2 Value
    INT32 GRP2_Sel_3;                             // DAC Volume Group 2 Select 3 Value
    INT32 GRP2_Sel_4;                             // DAC Volume Group 2 Select 4 Value
    INT32 GRP2_Sel_5;                             // DAC Volume Group 2 Select 5 Value
    INT32 GRP2_Sel_6;                             // DAC Volume Group 2 Select 6 Value
    INT32 GRP2_Sel_7;                             // DAC Volume Group 2 Select 7 Value
    INT32 GRP2_Sel_8;                             // DAC Volume Group 2 Select 8 Value
    INT32 GRP2_Sel_9;                             // DAC Volume Group 2 Select 9 Value
    INT32 GRP2_Sel_10;                            // DAC Volume Group 2 Select 10 Value
    INT32 GRP2_Sel_11;                            // DAC Volume Group 2 Select 11 Value
    INT32 GRP2_Sel_12;                            // DAC Volume Group 2 Select 12 Value
    INT32 GRP2_Sel_13;                            // DAC Volume Group 2 Select 13 Value
    INT32 GRP2_Sel_14;                            // DAC Volume Group 2 Select 14 Value
    INT32 GRP2_Sel_15;                            // DAC Volume Group 2 Select 15 Value
    INT32 GRP2_Sel_16;                            // DAC Volume Group 2 Select 16 Value
    INT32 GRP3_Sel_1;                             // DAC Volume Group 3 Select 1 Value
    INT32 GRP3_Sel_2;                             // DAC Volume Group 3 Select 2 Value
    INT32 GRP3_Sel_3;                             // DAC Volume Group 3 Select 3 Value
    INT32 GRP3_Sel_4;                             // DAC Volume Group 3 Select 4 Value
    INT32 GRP3_Sel_5;                             // DAC Volume Group 3 Select 5 Value
    INT32 GRP3_Sel_6;                             // DAC Volume Group 3 Select 6 Value
    INT32 GRP3_Sel_7;                             // DAC Volume Group 3 Select 7 Value
    INT32 GRP3_Sel_8;                             // DAC Volume Group 3 Select 8 Value
    INT32 GRP3_Sel_9;                             // DAC Volume Group 3 Select 9 Value
    INT32 GRP3_Sel_10;                            // DAC Volume Group 3 Select 10 Value
    INT32 GRP3_Sel_11;                            // DAC Volume Group 3 Select 11 Value
    INT32 GRP3_Sel_12;                            // DAC Volume Group 3 Select 12 Value
    INT32 GRP3_Sel_13;                            // DAC Volume Group 3 Select 13 Value
    INT32 GRP3_Sel_14;                            // DAC Volume Group 3 Select 14 Value
    INT32 GRP3_Sel_15;                            // DAC Volume Group 3 Select 15 Value
    INT32 GRP3_Sel_16;                            // DAC Volume Group 3 Select 16 Value
    INT32 GRP4_Sel_1;                             // DAC Volume Group 4 Select 1 Value
    INT32 GRP4_Sel_2;                             // DAC Volume Group 4 Select 2 Value
    INT32 GRP4_Sel_3;                             // DAC Volume Group 4 Select 3 Value
    INT32 GRP4_Sel_4;                             // DAC Volume Group 4 Select 4 Value
    INT32 GRP4_Sel_5;                             // DAC Volume Group 4 Select 5 Value
    INT32 GRP4_Sel_6;                             // DAC Volume Group 4 Select 6 Value
    INT32 GRP4_Sel_7;                             // DAC Volume Group 4 Select 7 Value
    INT32 GRP4_Sel_8;                             // DAC Volume Group 4 Select 8 Value
    INT32 GRP4_Sel_9;                             // DAC Volume Group 4 Select 9 Value
    INT32 GRP4_Sel_10;                            // DAC Volume Group 4 Select 10 Value
    INT32 GRP4_Sel_11;                            // DAC Volume Group 4 Select 11 Value
    INT32 GRP4_Sel_12;                            // DAC Volume Group 4 Select 12 Value
    INT32 GRP4_Sel_13;                            // DAC Volume Group 4 Select 13 Value
    INT32 GRP4_Sel_14;                            // DAC Volume Group 4 Select 14 Value
    INT32 GRP4_Sel_15;                            // DAC Volume Group 4 Select 15 Value
    INT32 GRP4_Sel_16;                            // DAC Volume Group 4 Select 16 Value
} ModuleDanville_DAC_Volume_MappingClass;
Name
Type
Usage
isHidden
Default value
Range
Units
Mapping_Saved
int
parameter
0:1
GRP1_Sel_1
int
parameter
0:1
GRP1_Sel_2
int
parameter
0:1
GRP1_Sel_3
int
parameter
0:1
GRP1_Sel_4
int
parameter
0:1
GRP1_Sel_5
int
parameter
0:1
GRP1_Sel_6
int
parameter
0:1
GRP1_Sel_7
int
parameter
0:1
GRP1_Sel_8
int
parameter
0:1
GRP1_Sel_9
int
parameter
0:1
GRP1_Sel_10
int
parameter
0:1
GRP1_Sel_11
int
parameter
0:1
GRP1_Sel_12
int
parameter
0:1
GRP1_Sel_13
int
parameter
0:1
GRP1_Sel_14
int
parameter
0:1
GRP1_Sel_15
int
parameter
0:1
GRP1_Sel_16
int
parameter
0:1
GRP2_Sel_1
int
parameter
0:1
GRP2_Sel_2
int
parameter
0:1
GRP2_Sel_3
int
parameter
0:1
GRP2_Sel_4
int
parameter
0:1
GRP2_Sel_5
int
parameter
0:1
GRP2_Sel_6
int
parameter
0:1
GRP2_Sel_7
int
parameter
0:1
GRP2_Sel_8
int
parameter
0:1
GRP2_Sel_9
int
parameter
0:1
GRP2_Sel_10
int
parameter
0:1
GRP2_Sel_11
int
parameter
0:1
GRP2_Sel_12
int
parameter
0:1
GRP2_Sel_13
int
parameter
0:1
GRP2_Sel_14
int
parameter
0:1
GRP2_Sel_15
int
parameter
0:1
GRP2_Sel_16
int
parameter
0:1
GRP3_Sel_1
int
parameter
0:1
GRP3_Sel_2
int
parameter
0:1
GRP3_Sel_3
int
parameter
0:1
GRP3_Sel_4
int
parameter
0:1
GRP3_Sel_5
int
parameter
0:1
GRP3_Sel_6
int
parameter
0:1
GRP3_Sel_7
int
parameter
0:1
GRP3_Sel_8
int
parameter
0:1
GRP3_Sel_9
int
parameter
0:1
GRP3_Sel_10
int
parameter
0:1
GRP3_Sel_11
int
parameter
0:1
GRP3_Sel_12
int
parameter
0:1
GRP3_Sel_13
int
parameter
0:1
GRP3_Sel_14
int
parameter
0:1
GRP3_Sel_15
int
parameter
0:1
GRP3_Sel_16
int
parameter
0:1
GRP4_Sel_1
int
parameter
0:1
GRP4_Sel_2
int
parameter
0:1
GRP4_Sel_3
int
parameter
0:1
GRP4_Sel_4
int
parameter
0:1
GRP4_Sel_5
int
parameter
0:1
GRP4_Sel_6
int
parameter
0:1
GRP4_Sel_7
int
parameter
0:1
GRP4_Sel_8
int
parameter
0:1
GRP4_Sel_9
int
parameter
0:1
GRP4_Sel_10
int
parameter
0:1
GRP4_Sel_11
int
parameter
0:1
GRP4_Sel_12
int
parameter
0:1
GRP4_Sel_13
int
parameter
0:1
GRP4_Sel_14
int
parameter
0:1
GRP4_Sel_15
int
parameter
0:1
GRP4_Sel_16
int
parameter
0:1
File Name: Danville_DAC_Volume_Mapping.m
 M=Danville_DAC_Filter_module(NAME, HASINPUTPIN)
 Copyright 2016.   Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
 $Revision: 1.1 $
