Danville_DIR_Active
DIR Active Status
This module reflects the validity of the DIR (Digital Input Receiver) stream coming from the SHARC DSP. If value is set to 1 means a valid signal. A value of zero means a signal does not exist or not locking. No available overrride for this feature.
typedef struct _ModuleDanville_DIR_Active
    INT32 DIR_Active_Val;                         // DIR Active Value
} ModuleDanville_DIR_ActiveClass;
Name
Type
Usage
isHidden
Default value
Range
Units
DIR_Active_Val
int
state
0:1
Description: DIR Active Bit
Data type: int
File Name: Danville_DIR_Active.m
 M=Danville_DIR_Active_module(NAME, HASINPUTPIN)
 Copyright 2016.  Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
 $Revision: 1.1 $
