Danville_DIR_Select
DIR Select Control
This module allows users to select the hardware connection that feeds the DIR perihperal. Please refer to the accompanying documentation of the target hardware The default value field gives users to enter a one time initialization value for this module instance. Clicking the overrride checkbox allows user to use a value via the inspector while the value from the canvass is ignored.
typedef struct _ModuleDanville_DIR_Select
    INT32 DIR_Select_Val;                         // Digital Out Value
    INT32 DIR_Select_OLD_Val;                     // Digital Out OLD Value
    INT32 DIR_Select_Default_Val;                 // Digital Out Default Locator
    INT32 DIR_Select_Override;                    // Digital Out Override
} ModuleDanville_DIR_SelectClass;
Name
Type
Usage
isHidden
Default value
Range
Units
DIR_Select_Val
int
parameter
0:1
DIR_Select_OLD_Val
int
parameter
0:1
int
parameter
0:1
DIR_Select_Override
int
parameter
0:1
Description: Danville DIR Select
Data type: int
Channel range: 1
Block size range: 1
File Name: Danville_DIR_Select.m
 M=Danville_DIR_Select_module(NAME, HASINPUTPIN)
 Copyright 2016.  Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
 $Revision: 1.1 $
