ScalerControlBlockSmoothedFract32
Linear multichannel smoothly varying scaler with control pin
Scales all input channels by the gain values taken from the first input pin. Changes to the gain parameter are exponentially smoothed (first order IIR) by the smoothingTime parameter on the block basis. Internally, currentGain represents the instantaneous smoothed gain that is applied. The module starts with a current gain equal to 0 and then slews towards the gain specified on the control input. The module supports multiple input and output pins and the number of pins is specified by the second argument NUMPINS. By default, NUMPINS = 1. All audio inputs and outputs are in fract32 format. The processing function is implemented using a fractional multiply by the smoothed gain followed by a fixed bit right-shift at the end.
The module argument DATATYPE specifies the data type of the control input. DATATYPE = 0 (the default) indicates that the control pin will be fractional with Q9.23 format. Alternatively, if DATATYPE = 1 then the control input is a floating-point value.
The control input can have any block size and any number of channels. The module uses the first sample value of the control pin at the target gain; all other values are ignored.
typedef struct _ModuleScalerControlBlockSmoothedFract32
    INT32 dataType;                               // Specifies data type at input control pin (0=Q9.31, 1=float)
    fract32 currentGain;                          // Instantaneous gain applied by the module. This is also the starting gain of the module.
    fract32 smoothingCoeff;                       // Smoothing coefficient
} ModuleScalerControlBlockSmoothedFract32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
smoothingTime
float
parameter
10
0:1000
msec
dataType
int
const
Unrestricted
currentGain
fract32
state
1
Unrestricted
linear
smoothingCoeff
fract32
derived
1
0.002081
Unrestricted
Description: gain input
Data type: fract32
Channel range: 1
Description: audio input
Data type: fract32
Channel range: Unrestricted
Description: audio output
Data type: fract32
File Name: scaler_control_block_smoothed_fract32_module.m
 M=scaler_control_block_smoothed_fract32_module(NAME, NUMPINS, DATATYPE)
 The scaler operates on fractional 32-bit values. The scaler
 accepts multichannel input and scales all channels by the same
 value.  The input and output audio signals are in standard fract32
 format (Q1.31).  Arguments:
    NAME - name of the module.
    NUMPINS - number of input and output audio pins (default = 1)
    DATATYPE - data type of the control signal.  You can select
      between Q9.23 (DATATYPE = 0, the default) or floating-point
      (DATATYPE = 1)
 Copyright 2014.  DSP Concepts, Inc.  All Rights Reserved.
