WaveOneShotPlayerRAMFract32
One-shot Wave Player supporting pitch shifting
This module outputs wave data triggered via an input pin. The input .trigger is a Boolean value which if set starts playback. Playback continues until the end of the file is reached and then it stops. Retrigger while being in the middle of the playback has no effect and will be ignored. The module supports multichannel such that, if the wave file has more channels than provided to the module argument then only channels up to output pin channels will be used. If the wave file has less channels than output pin channels, then the remaining output channels will be muted.
typedef struct _ModuleWaveOneShotPlayerRAMFract32
    INT32 smoothingTime;                          // Time constant of the pitch smoothing process
    INT32 smoothingFactor;                        // Update rate for smoothing coeffs (per block)
    FLOAT32 normRate;                             // Rate of data used to compute the ratio for normalized players
    FLOAT32 maxRate;                              // Highest allowed rate of playback that can be specified
    INT32 NCOFracBits;                            // Number of least-significant bits for the *fractional* part of the NCO word (word size: 32)
    INT32 waveLength;                             // Number of samples in currently loaded file
    INT32 fIndex;                                 // Current index in the wave file
    FLOAT32 currentFStep;                         // Current (smoothed) rate at which audio is read from the input buffer
    INT32 triggerPrev;                            // State trigger signal to determine falling edge
    INT32 triggerLatched;                         // State trigger denoting player is active
    INT32 waveSR;                                 // Actual sample rate of the wave file.
    INT32 waveNumChannels;                        // Number of channels in the wave file.
    FLOAT32 scaleFactor;                          // Scale factor for playback rate
    FLOAT32 smoothingCoeff;                       // Smoothing (pitch) coefficient
    INT32 NCOIntBits;                             // Number of most-significant bits for the *integer* part of the NCO word (word size: 32). By default: 20 bits
    FLOAT32 formatF;                              // Integer value of left-shift by NCOFracBits. Determines the precision of the linear interpolation.
    FLOAT32 formatI;                              // Integer value of left-shift by NCOIntBits. Determines the maximum playback rate and the maximum size of a wave file in samples.
    UINT32 pinID;                                 // Specifies which control pins are available.
    INT32* waveBuffer;                            // Data transferred from PC to target DSP via this buffer.
} ModuleWaveOneShotPlayerRAMFract32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
smoothingTime
int
parameter
10
0:1000
msec
smoothingFactor
int
parameter
4
1:512
normRate
float
const
1
Unrestricted
maxRate
float
const
2
Unrestricted
NCOFracBits
int
const
12
Unrestricted
waveLength
int
derived
100400
Unrestricted
fIndex
int
state
Unrestricted
currentFStep
float
state
1
Unrestricted
triggerPrev
int
state
Unrestricted
triggerLatched
int
state
Unrestricted
waveSR
int
derived
1
48000
Unrestricted
waveNumChannels
int
derived
1
1
Unrestricted
scaleFactor
float
derived
1
1
Unrestricted
smoothingCoeff
float
derived
1
0.1248
Unrestricted
NCOIntBits
int
derived
1
20
Unrestricted
formatF
float
derived
1
4096
Unrestricted
formatI
float
derived
1
524300
Unrestricted
pinID
uint
const
1
1
Unrestricted
waveBuffer
int*
parameter
[50209 x 1]
Unrestricted
Data type: int
Channel range: 1
Block size range: 1
Data type: float
Channel range: 1
Block size range: 1
Description: output data
Data type: fract32
Description: playing state
Data type: int
File Name: wave_oneshot_player_ram_fract32_module.m
