Danville_DAC_Mute
DAC Mute Control
DAC Mute control.
typedef struct _ModuleDanville_DAC_Mute
INT32 DAC_Mute_Val; // DAC Mute Value
INT32 DAC_Mute_Default_Val; // DAC Mute Default Value
INT32 DAC_Mute_OLD_Val; // DAC Mute Old Value
INT32 DAC_Mute_Override; // DAC Mute Override
} ModuleDanville_DAC_MuteClass;
DAC_Mute_Val | int | parameter | 0 | 0 | 0:1 | |
DAC_Mute_Default_Val | int | parameter | 0 | 0 | 0:1 | |
DAC_Mute_OLD_Val | int | parameter | 0 | 0 | 0:1 | |
DAC_Mute_Override | int | parameter | 0 | 0 | 0:1 |
Description: DAC Mute Value
Data type: int
Channel range: 1
Block size range: 1
File Name: Danville_DAC_Mute.m
M=Danville_DAC_Mute_module(NAME, HASINPUTPIN)
NAME - name of the module.
Author: E. Enrique
$Revision: 1.1 $
AudioWeaverModule [This tag makes it appear under awe_help]
