SecondOrderFilterSmoothedCascadeV2
The behavior of the cascade filters are controlled by the filterType arrary. The variable, filterType is an integer in the range from 0 to 22 inclusive.
The following list discusses the various filter types and which variables are active in each case.
filterType=1, Linear gain. [gain].
filterType=16, 1st order Bessel low pass filter. [freq].
filterType=23, 2nd order Resonant bandpass filter. [freq, Q].
The hidden variable .bulkParamsUpdate can be used to control sofCoeffs calculation after all parameters are updated. This is useful when changing all four parameters, filterType, freq, gain and Q, simultaneously from host, to avoid intermediate coefficient transitions. Set this variable before writing filter parameters and then clear this after all filter parameters are updated.
On the ADI SHARC+ platforms, except ADSP-2157x and ADSP-2158x, the module make use of IIR Accelerators, in legacy mode, to optimize the processing time. The processing load is distributed as 1 channel processing in IIRA is equivalent to 2 channel core processing. i.e. the IIRA channels=floor(numChannels/3). As the accelerators access data by DMA, when the dm and pm caches are enabled, extra cycles are needed to maintain cache coherence. It is highly recommended to increase the allocation priority of this module instance in the signal flow to have a larger chance to allocate in the AWE fast heaps. In this way, the overhead from accelerator can be minimized. If any of this module instances allocated in the AWE slow heap, please note that the CPU load might be higher than without IIRA due to cache coherence maintenance. Maximum number of channels that can be processed in IIR Accelerator is limited to 32 and the remaining channels are processed by the core. i.e. IIRA channels=min(floor(numChannels/3), 32)
On the processors of 2159x where 8 IIR accelerators are available with dual SHARC+ cores, 4 IIR accelerators are statically reserved for each core. The processing load is distributed as IIRA channels = floorf(numChannels/3) * 2. i.e. if the numChannels are 10 then 6 channels are processed in 4 IIR accelerators in parallel with 4 channels in core processing. On SHARC+ processor, additional memory is allocated for accelerator TCB with size of numAcceleratorChannels*13. Also separate coefficient/state buffer is allocated as per the accelerator requirement.
typedef struct _ModuleSecondOrderFilterSmoothedCascadeV2
INT32 numStages; // Number of cascaded stages of the second order filter.
FLOAT32 smoothingTime; // Time constant of the smoothing process.
INT32 updateActive; // Specifies whether the filter coefficients are updating (=1) or fixed (=0).
FLOAT32 smoothingCoeff; // Smoothing coefficient. This is computed based on the smoothingTime, sample rate, and block size of the module.
INT32 bulkParamsUpdate; // State variable to handle bulk changes in parameters.
INT32* filterType; // Selects the type of filter that is implemented by the module: Bypass=0, Gain=1, Butter1stLPF=2, Butter2ndLPF=3, Butter1stHPF=4, Butter2ndHPF=5, Allpass1st=6, Allpass2nd=7, Shelf2ndLow=8, Shelf2ndLowQ=9, Shelf2ndHigh=10, Shelf2ndHighQ=11, PeakEQ=12, Notch=13, Bandpass=14, Bessel1stLPF=15, Bessel1stHPF=16, AsymShelf1stLow=17, AsymShelf1stHigh=18, SymShelf1stLow=19, SymShelf1stHigh=20, VariableQLPF=21, VariableQHPF=22 Resonant=23.
FLOAT32* freq; // Cutoff frequency of the filter, in Hz.
FLOAT32* gain; // Amount of boost or cut to apply, in dB if applicable.
FLOAT32* Q; // Specifies the Q of the filter, if applicable.
FLOAT32* targetCoeffs; // Matrix of filter target coefficients. The size of the matrix is 5 x numStages. Each column contains the variables for a biquad arranged as [b0; b1; b2; a1; a2].
FLOAT32* currentCoeffs; // Matrix of filter current coefficients. The size of the matrix is 5 x numStages. Each column contains the variables for a biquad arranged as [b0; b1; b2; a1; a2].
FLOAT32* state; // State variables. 2*numChannels per section.
void * hardware_specific_struct_pointer; // This is the internal array used for ADI IIR accelerator. Size is determined internally
} ModuleSecondOrderFilterSmoothedCascadeV2Class;
numStages | int | const | 0 | 2 | 1:1:32 | |
smoothingTime | float | parameter | 0 | 10 | 0:1:1000 | msec |
updateActive | int | parameter | 1 | 1 | 0:1 | |
smoothingCoeff | float | derived | 1 | 0.06449 | Unrestricted | |
bulkParamsUpdate | int | state | 1 | 0 | Unrestricted | |
filterType | int* | parameter | 0 | [1 x 2] | 0:23 | |
freq | float* | parameter | 0 | [1 x 2] | 10:0.1:23990 | Hz |
gain | float* | parameter | 0 | [1 x 2] | -24:0.1:24 | dB |
Q | float* | parameter | 0 | [1 x 2] | 0:0.1:20 | |
targetCoeffs | float* | derived | 0 | [5 x 2] | Unrestricted | |
currentCoeffs | float* | state | 0 | [5 x 2] | Unrestricted | |
state | float* | state | 1 | [2 x 2] | Unrestricted | |
hardware_specific_struct_pointer | void * | state | 1 | Unrestricted |
Description: audio input
Data type: float
Channel range: Unrestricted
Description: audio output
Data type: float
File Name: second_order_filter_cascade_v2_module.m
M=second_order_filter_cascade_v2_module(NAME, ISSMOOTH, NUMSTAGES)
of coefficients.
Arguments:
NAME - name of the module.
