AWE Designer
AWE Designer 8.D.2.2
2023-NOVEMBER-8
New Features
Module documentation and Designer User's Guides are now hosted on DSP Concepts website
Enhancements
CPU load per core is now displayed in AWE_Server if target has defined core affinities
CPU overflows in AWE_Server now calculated correctly for layouts running across multiple cores (SMP)
Bug Fixes
Module properties window will no longer close when a layout is run
Matlab will now force values to be within min/max range set by the module variable or array
Fixed failure with virtual modules in feedback wire path
Fixed issue with module compatibility with previously saved AWJs
Fixed loading of AWD's that contain subsystems with no input or output pin
Fixed propagation of accumulated delay through subsystems
Update AWE_Server to do deferred processing on all Native instances, not just instance 0
AWE Designer 8.D.2.1
2023-SEPTEMBER-18
New Features
Enhancements
Bug Fixes
AWE Designer 8.D.1.3
2023-JULY-21
Enhancements
Bug Fixes
AWE Designer 8.D.1.2
2023-JUNE-2
Enhancements
Bug Fixes
AWE Designer 8.D.1.1
2023-FEBRUARY-15
Enhancements
Bug Fixes
AWE Designer 8.C.2.7
2022-DECEMBER-05
New Feature
Enhancements
Bug Fixes
Fixed
AWE Designer 8.C.2.6
2022-SEPTEMBER-21
New Feature
Enhancements
Bug Fixes
AWE Designer 8.C.2.5.A
2022-JULY-21
Bug Fixes
2022-JULY-05
New Features
Enhancements
Bug Fixes
AWE Designer 8.C.2.4
2022-MAY-12
Enhancements
Updated
Bug Fixes (Modules)
Bug Fixes (Canvas)
Bug Fixes (General)
Fixed failure for
AWE Designer 8.C.2.3.A
2022-APRIL-15
New Feature
2022-APRIL-6
New Features
Enhancements
modVarvalues
Bug Fixes (General)
Bug Fixes (Interface)
Bug Fixes (Modules)
Designer no longer displays
AWE Designer 8.C.2.2
2022-JANUARY-7
New Features
Enhancements
Bug Fixes
Default
