Danville_DAC_Volume
DAC Volume Control
This module controls the DAC attenuator registers The locator refers to the DAC channel grouping dictated by the DAC Volume Mapping module.
typedef struct _ModuleDanville_DAC_Volume
    FLOAT32 DAC_Volume_Val;                       // DAC Volume
    FLOAT32 DAC_Volume_Default_Val;               // DAC Default Volume
    FLOAT32 DAC_Volume_OLD_Val;                   // DAC OLD Volume
    INT32 DAC_Volume_Locator;                     // DAC Volume Locator
    INT32 DAC_Volume_Override;                    // DAC Volume Override
} ModuleDanville_DAC_VolumeClass;
Name
Type
Usage
isHidden
Default value
Range
Units
DAC_Volume_Val
float
parameter
-128:0.5:0
float
parameter
-128:0.5:0
DAC_Volume_OLD_Val
float
parameter
-128:0.5:0
DAC_Volume_Locator
int
parameter
0:3
DAC_Volume_Override
int
parameter
0:1
Description: DAC Volume
Data type: float
Channel range: 1
Block size range: 1
File Name: Danville_DAC_Volume.m
 M=Danville_DAC_Volume_module(NAME, HASINPUTPIN)
 Copyright 2016.  Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
