AllpassDelay
![](../../__attachments/2984837204/image-20230125-192435.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
![](../../__attachments/2984837204/image-20230125-192520.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
The filter has a constant magnitude response of 1.0 and a non-zero phase response. The filter has a DC gain of 1.0.
MAXDELAY specifies the size of the delay buffer. At run-time, you can vary the delay in the range 0 to MAXDELAY as well as the coefficient
![](../../__attachments/2984837204/image-20240108-190320.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
. If the delay is equal to 0, then the algorithm processes the audio data as a bypass. The third argument OUTPUTSTATE is a Boolean which specifies whether the module has an optional 2nd output pin. The 2nd output pin gets the output of the delay buffer as shown above.
typedef struct _ModuleAllpassDelay
FLOAT32* state; // State variable array
} ModuleAllpassDelayClass;
state | float* | state | 1 | [1 x 101] | Unrestricted |
Description: audio input
Data type: float
Channel range: Unrestricted
Description: audio output
Data type: float
Data type: float
File Name: allpass_delay_module.m
Delay based allpass (1st order), using integer length delay. Arguments:
NAME - name of the module.
OUTPUTSTATE = 0.
