AllpassDelay16Fract32
![](../../__attachments/2984509526/image-20230125-192435.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
![](../../__attachments/2984509526/image-20230125-192520.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
The filter has a constant magnitude response of 1.0 and a non-zero phase response. The filter has a DC gain of 1.0.
MAXDELAY specifies the size of the delay buffer. At run-time, you can vary the delay in the range 0 to MAXDELAY as well as the coefficient
![](../../__attachments/2984509526/image-20240108-191306.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
. If the delay is equal to 0, then the algorithm processes the audio data as a bypass. The third argument OUTPUTSTATE is a Boolean which specifies whether the module has an optional 2nd output pin. The 2nd output pin gets the output of the delay buffer as shown above.
typedef struct _ModuleAllpassDelay16Fract32
 fract32 coefFract32; // Feedback/-feedforward fractional coefficient for the allpass delay.
 INT32 postShift; // Number of bits to shift after the fractional multiply. This is based on coef.range.
 INT32* state; // State variable array
} ModuleAllpassDelay16Fract32Class;
coefFract32 | fract32 | derived | 0 | 0.5 | Unrestricted | |
postShift | int | derived | 1 | 0 | Unrestricted | |
state | int* | state | 1 | [51 x 1] | Unrestricted |
Description: audio input
Data type: fract32
Channel range: Unrestricted
Description: audio output
Data type: fract32
Data type: fract32
File Name: allpass_delay_module.m
M = allpass_delay16_fract32_module(NAME, MAXDELAY, OUTPUTSTATE)
Fract32 version of Delay based allpass (1st order), using integer length
delay. This module uses 16-bit internal state variables in order to save on
memory. Arguments:
NAME - name of the module.
OUTPUTSTATE = 0.
