PhaseDifferencePostFilter
Phase Difference Post Filter
typedef struct _ModulePhaseDifferencePostFilter
    FLOAT32 filterDelayThreshold;                 // Threshold to determine if a time-freq bin is within the specified direction
    FLOAT32 targetWidth;                          // The width of the target direction, in degrees. Calculated from targetDir, micSpacing, and filterDelayThreshold
    FLOAT32 maskAttenDB;                          // dB units - attenuation in the time-freq bin if the sound from that bin is not in the specified direction
    FLOAT32 maskAtten;                            // Linear units - attenuation in the time-freq bin if the sound from that bin is not in the specified direction
    FLOAT32 timeDomainSR;                         // Sample rate - in time domain
    FLOAT32 targetDir;                            // Target direction, in degrees. NOT Implemented
    FLOAT32 micSpacing;                           // Mic Spacing, in meters.
    INT32 fftSize;                                // FFT Size
    INT32 numBins;                                // Number of bins
    INT32 numFilters;                             // Number of Gammatone Filters
    FLOAT32 epsilon;                              // A small number
    FLOAT32* gtFilterMag;                         // Matrix holding the magnitude of gammatone filter coefficients (real)
    FLOAT32* phaseDiff;                           // Phase difference, in radians. Part of scratch.
    FLOAT32* oneOverExpectedPhaseDiff;            // One over the expected phase difference.
    FLOAT32* W;                                   // Gammatone domain weights
    FLOAT32* mu;                                  // Mask
    FLOAT32* mu_g;                                // Mask after Gammatone filterbank
} ModulePhaseDifferencePostFilterClass;
Name
Type
Usage
isHidden
Default value
Range
Units
float
parameter
0.2
0:10
targetWidth
float
derived
6.5544
Unrestricted
maskAttenDB
float
parameter
-40
-60:0
maskAtten
float
derived
0.01
Unrestricted
timeDomainSR
float
const
16000
Unrestricted
targetDir
float
parameter
Unrestricted
micSpacing
float
parameter
0.075
Unrestricted
fftSize
int
const
512
Unrestricted
numBins
int
const
257
Unrestricted
numFilters
int
const
40
Unrestricted
epsilon
float
const
1e-19
Unrestricted
gtFilterMag
float*
derived
[256 x 40]
Unrestricted
phaseDiff
float*
derived
1
[257 x 1]
Unrestricted
float*
derived
1
[257 x 1]
Unrestricted
W
float*
derived
1
[40 x 1]
Unrestricted
mu
float*
derived
1
[257 x 1]
Unrestricted
mu_g
float*
derived
1
[257 x 1]
Unrestricted
Description: input
Data type: float
Channel range: 2
Block size range: 257
Complex support: Complex
Description: output
Data type: float
Scratch Pins
Channel count: 1
Block size: 257
Sample rate: 48000
Channel count: 1
Block size: 257
Sample rate: 48000
File Name: phase_difference_post_filter_module.m
 M=phase_difference_post_filter_module(NAME, numFilters, fftSize)
 Creates a phase difference post filter module
 Currently, only 2 channels are supported.
  description TBD
 Arguments:
     NAME - name of the module.
