ZeroCrossingDetectorFract32
Zero crossing detector
Multichannel zero-crossing detector, running at the sampling rate. The module outputs a 1.0 whenever a zero crossing is detected and 0.0 otherwise. The detectorType parameter controls the behavior of the detector.
If detectorType == 0, then all zero crossing are detected. If detectorType > 0, then only positive transitions (negative->positive) are detected. If detectorType < 0, then only negative transitions (positive->negative) are detected.
typedef struct _ModuleZeroCrossingDetectorFract32
    INT32 detectorType;                           // Determines which zero crossings are detected. 0=all, >0 negative->positive, <0 positive->negative
    INT32* lastSign;                              // Holds the sign of the last input value. This is an array so that multiple channels can be supported.
} ModuleZeroCrossingDetectorFract32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
detectorType
int
parameter
-1:1
lastSign
int*
state
1
[1 x 1]
Unrestricted
Description: audio input
Data type: fract32
Channel range: Unrestricted
Description: audio output
Data type: fract32
File Name: zero_cross_detector_fract32_module.m
 M=zero_cross_detector_fract32_module(NAME)
 Creates a zero crossing detector module for use in the Audio Weaver.
 The module has a single multichannel input pin and a single output
 pin of the same size as the input pin.  The module outputs a 1.0
 Arguments:
    NAME - name of the module.
 The .detectorType field of the instance structure controls the
