Danville_Digital_In
Digital Input Control
This module takes a value from the target hardware and outputs the value to wards the Audio Weaver Canvass Please refer to the accompanying documentation of the target hardware Locator values serves as an ID which associates the module to information coming from a preassigned hardware trigger Clicking the overrride checkbox allows user to use a value via the inspector while the value from the target hardware is ignored.
typedef struct _ModuleDanville_Digital_In
INT32 Digital_In_Val; // Digital In Value
INT32 Digital_In_Locator; // Digital In Locator
INT32 Digital_In_Override; // Digital In Override
} ModuleDanville_Digital_InClass;
Digital_In_Val | int | parameter | 0 | 0 | 0:65535 | |
Digital_In_Locator | int | parameter | 0 | 0 | 0:31 | |
Digital_In_Override | int | parameter | 0 | 0 | 0:1 |
Description: Switch Bit
Data type: int
File Name: Danville_Digital_In.m
function M=Danville_Digital_In_module(NAME)
Author: E. Enrique
$Revision: 1.1 $
