SOFSmoothedCascadeFract32
General 2nd order filter cascade designer with smoothing
This module implements a general purpose second order filter Cascade that is capable of realizing many different filter types. The module performs internal smoothing allowing the filters to be updated without introducing clicks. In all cases, the module implements an underlying Cascade second order filter. First order filters are realized by setting some of the second order coefficients to zero.
The behavior of the filter is controlled by the Cascade filterType parameter. filterType is an integer in the range from 0 to 14 inclusive. After specifying filterType, set you adjust the filter parameters by setting the fields .gain, .freq, and .Q. Some filter types use only a subset of these parameters and ignore the others.
The following table discusses the various filter types and which variables are active in each case. The .freq variable controls the center frequency of the filter; .gain determines the boost or cut, in dB; .Q determines how sharp the filter is. Low .Q values lead to broad filters. High .Q values lead to narrow filters.
filterType = 0, Simple pass through with unity gain.
filterType = 1, Gain in dB [.gain].
filterType = 2, 1st order Butterworth low pass filter [.freq]
filterType = 3, 2nd order Butterworth low pass filter [.freq]
filterType = 4, 1st order Butterworth high pass filter [.freq]
filterType = 5, 2nd order Butterworth high pass filter [.freq]
filterType = 6, 1st order allpass filter [.freq]
filterType = 7, 2nd order allpass filter [.freq, .Q]
filterType = 8, 2nd order low shelf. It allows you to vary the gain of the low frequencies. The high frequencies have a gain of 1.0. [.freq, .gain].
filterType = 9, 2nd order low shelf w/Q. It allows you to vary the gain of the low frequencies. The high frequencies have a gain of 1.0. This module also has an adjustable Q parameter. [.freq, .gain, .Q].
filterType = 10, 2nd order high shelf. It allows you to vary the gain of the high frequencies. The low frequencies have a gain of 1.0. [.freq, .gain].
filterType = 11, 2nd order high shelf w/Q. It allows you to vary the gain of the high frequencies. The low frequencies have a gain of 1.0. This module also has an adjustable Q parameter. [.freq, .gain, .Q].
filterType = 12, 2nd order peaking filter. It has unity gain except around the specified frequency. By varying .gain, you can get a peak or a notch in the frequency band. [.freq, .gain, .Q].
filterType = 13, 2nd order notch filter. It has unity gain except around the specified frequency. At the specified frequency, the filter has a true notch with -inf dB gain. [.freq, .Q].
filterType = 14, 2nd order bandpass filter. It has unity gain at the specified frequency and falls off in both directions. The bandwidth of the filter is determined by Q. [.freq, .Q]
filterType = 15, 1st order Bessel low pass filter [.freq]
filterType = 16, 1st order Bessel high pass filter [.freq]
filterType = 17, 1st order asymmetrical low shelf [.freq, .gain]
filterType = 18, 1st order asymmetrical high shelf [.freq, .gain]
filterType = 19, 1st order symmetrical low shelf [.freq, .gain]
typedef struct _ModuleSOFSmoothedCascadeFract32
INT32 numStages; // Number of cascaded stages of the second order filter.
FLOAT32 smoothingTime; // Time constant of the smoothing process
INT32 updateActive; // Specifies whether the filter coefficients are updating (=1) or fixed (=0)
fract32 smoothingCoeff; // Smoothing coefficient. This is computed based on the smoothingTime, sample rate, and block size of the module
INT32 postShift; // Number of bits to shift
FLOAT32 twoPowMinusPostShift; // 2^(-postShift). Used by to streamline the operation of the set function
INT32* filterType; // Selects the type of filter that is implemented by the module: Bypass=0, Gain=1, Butter1stLPF=2, Butter2ndLPF=3, Butter1stHPF=4, Butter2ndHPF=5, Allpass1st=6, Allpass2nd=7, Shelf2ndLow=8, Shelf2ndLowQ=9, Shelf2ndHigh=10, Shelf2ndHighQ=11, PeakEQ=12, Notch=13, Bandpass=14, Bessel1stLPF=15, Bessel1stHPF=16, AsymShelf1stLow=17, AsymShelf1stHigh=18, SymShelf1stLow=19, SymShelf1stHigh=20, VariableQLPF=21, VariableQHPF=22.
FLOAT32* freq; // Cutoff frequency of the filter
FLOAT32* gain; // Amount of boost or cut to apply, in decibels (if applicable)
FLOAT32* Q; // Specifies the Q of the filter, if applicable
FLOAT32* coeffs; // coefficients
fract32* target_coeffsFract32; // Matrix of filter coefficients. The size of the matrix is 5 x numStages. Each column contains the variables for a biquad arranged as [b0; b1; b2; a1; a2].
fract32* current_coeffsFract32; // Matrix of filter coefficients. The size of the matrix is 5 x numStages. Each column contains the variables for a biquad arranged as [b0; b1; b2; a1; a2].
fract32* state; // State variables. 4 per channel per stage
} ModuleSOFSmoothedCascadeFract32Class;
numStages | int | const | 0 | 2 | 1:1:32 | |
smoothingTime | float | parameter | 0 | 10 | 0:1:1000 | msec |
updateActive | int | parameter | 1 | 1 | 0:1 | |
smoothingCoeff | fract32 | derived | 1 | 0.06449 | Unrestricted | |
postShift | int | derived | 1 | 1 | Unrestricted | |
twoPowMinusPostShift | float | derived | 1 | 0.5 | Unrestricted | |
filterType | int* | parameter | 0 | [1 x 2] | 0:22 | |
freq | float* | parameter | 0 | [1 x 2] | 10:0.1:23990 | Hz |
gain | float* | parameter | 0 | [1 x 2] | -24:0.1:24 | dB |
Q | float* | parameter | 0 | [1 x 2] | 0:0.1:20 | |
coeffs | float* | parameter | 0 | [5 x 2] | Unrestricted | |
target_coeffsFract32 | fract32* | derived | 0 | [5 x 2] | Unrestricted | |
current_coeffsFract32 | fract32* | state | 0 | [5 x 2] | Unrestricted | |
state | fract32* | state | 1 | [4 x 2] | Unrestricted |
Description: audio input
Data type: fract32
Channel range: Unrestricted
Description: audio output
Data type: fract32
File Name: second_order_filter_cascade_fract32_module.m
M=second_order_filter_cascade_fract32_module(NAME, ISSMOOTH, NUMSTAGES)
of standard filter types. The filter operates on multiple interleaved
coefficients. Arguments:
NAME - name of the module.
