WaveOneShotPlayerFFSFract32
One-shot Wave Player supporting pitch shifting
This module outputs wave data triggered via an input pin. It extracts wave data from AWE Flash File System container on control input pin fsInstance, based on WAVFILE argument. User has to specify the file name as an argument and can also change file name directly into fileName array as 32-bit packed data during run time. The input .trigger is a Boolean value which if set starts playback. Playback continues until the end of the file is reached and then it stops. Retrigger while being in the middle of the playback has no effect and will be ignored. The module supports multichannel such that, if the wave file has more channels than provided to the module argument then only channels up to output pin will be used. If the wave file has less channels than output pin channels, then the remaining output channels will be muted.
If any errors occurs in the module, it is captured in the parameter .errorCodes. Please check in Errors.h for the meaning of error code returned.
typedef struct _ModuleWaveOneShotPlayerFFSFract32
    INT32 smoothingTime;                          // Time constant of the pitch smoothing process
    INT32 smoothingFactor;                        // Update rate for smoothing coeffs (per block)
    FLOAT32 normRate;                             // Rate of data used to compute the ratio for normalized players
    FLOAT32 maxRate;                              // Highest allowed rate of playback that can be specified
    INT32 NCOFracBits;                            // Number of least-significant bits for the *fractional* part of the NCO word (word size: 32)
    INT32 waveLength;                             // Number of samples in currently loaded file
    INT32 fsInstance;                             // AWE flash file system instance pointer
    INT32 fIndex;                                 // Current index in the wave file
    FLOAT32 fIndexFract;                          // Current fract index in the wave file
    INT32 errorCode;                              // Captures errors that could arise in the module C code. Appears on the inspector
    INT32 isReady;                                // Boolean that indicates the module is not ready to output data
    INT32 waitForMuteDone;                        // Internal flag to check if the smooth mute is done
    FLOAT32 currentFStep;                         // Current (smoothed) rate at which audio is read from the input buffer
    INT32 triggerPrev;                            // State trigger signal to determine rising edge
    INT32 triggerLatched;                         // State trigger denoting player is active
    INT32 waveSR;                                 // Actual sample rate of the wave file.
    INT32 waveNumChannels;                        // Number of channels in the wave file.
    INT32 waveBit;                                // Wave data sample bit resolution.
    FLOAT32 scaleFactor;                          // Scale factor for playback rate
    FLOAT32 smoothingCoeff;                       // Smoothing (pitch) coefficient
    INT32 NCOIntBits;                             // Number of most-significant bits for the *integer* part of the NCO word (word size: 32). By default: 20 bits
    FLOAT32 formatF;                              // Integer value of left-shift by NCOFracBits. Determines the precision of the linear interpolation.
    FLOAT32 formatI;                              // Integer value of left-shift by NCOIntBits. Determines the maximum playback rate and the maximum size of a wave file in samples.
    UINT32 pinID;                                 // Specifies which control pins are available.
    INT32* fileName;                              // Name of wave file to playback
    INT32* fileNamePrev;                          // Name of wave file to playback
    void * muteModPtr;                            // Internal pointer to mute module to mute before reconfiguration
    void * unMuteModPtr;                          // Internal pointer to mute module to unmute after reconfiguration
    UINT32 * fsInstancePtr;                       // AWE flash file system instance pointer
    UINT32 * waveBuffer;                          // State variable holds the start address of the wave file in filesystem.
} ModuleWaveOneShotPlayerFFSFract32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
smoothingTime
int
parameter
10
0:1000
msec
smoothingFactor
int
parameter
4
1:512
normRate
float
const
1
Unrestricted
maxRate
float
const
2
Unrestricted
NCOFracBits
int
const
12
Unrestricted
waveLength
int
derived
Unrestricted
fsInstance
int
state
Unrestricted
fIndex
int
state
Unrestricted
fIndexFract
float
state
Unrestricted
errorCode
int
state
Unrestricted
isReady
int
state
Unrestricted
waitForMuteDone
int
state
Unrestricted
currentFStep
float
state
1
Unrestricted
triggerPrev
int
state
Unrestricted
triggerLatched
int
state
Unrestricted
waveSR
int
derived
1
Unrestricted
waveNumChannels
int
derived
1
Unrestricted
waveBit
int
derived
1
Unrestricted
scaleFactor
float
derived
1
1
Unrestricted
smoothingCoeff
float
derived
1
Unrestricted
NCOIntBits
int
derived
1
20
Unrestricted
formatF
float
derived
1
Unrestricted
formatI
float
derived
1
Unrestricted
pinID
uint
const
1
1
Unrestricted
fileName
int*
parameter
1
[14 x 1]
Unrestricted
fileNamePrev
int*
state
1
[14 x 1]
Unrestricted
muteModPtr
void *
state
1
Unrestricted
unMuteModPtr
void *
state
1
Unrestricted
fsInstancePtr
UINT32 *
state
1
Unrestricted
waveBuffer
UINT32 *
state
1
Unrestricted
Data type: int
Channel range: 1
Block size range: 1
Description: AWE file system instance pointer
Data type: int
Channel range: Unrestricted
Block size range: 1
Data type: float
Channel range: 1
Block size range: 1
Description: output data
Data type: fract32
Description: playing state
Data type: int
File Name: wave_oneshot_player_ffs_fract32_module.m
