End-to End Example
The goal for this section is to give a complete example that goes from a signal flow, to generating target files, to controlling the processing via the TinyMix commands. It will show a very simple signal flow that does some multicore operations. The goal is to give a high-level overview of how the pieces of the system work together.
  • Create a simple multicore example
  • Highlight some items for object ID
  • Use a control array for standard I/O
  • Generating target files
  • Generate the boot image
  • System boots and runs
  • Then use the HLOS to get and set parameters
