AWE Designer
AWE Designer 8.D.1.2
2023-JUNE-2
Enhancements
  • Will now detect if an input WAV file is missing before building the layout
  • Improved robustness and usability of layout variables
  • Updated taskbar icons for Designer and AWE_Server applications
  • Now allowed to replace a RUS that has the same name as an existing module
  • Improved notification to user when overwriting a CRUS
  • Removed 'subsystem' tag from default module search list for new RUS/CRUS
  • Removed unneeded information from AWJ files to make file size smaller
  • Column names for arrays in the module properties panel will now show associated channel names when appropriate
  • Added multiple sections and improved clarity to DocHub Designer documentation
Bug Fixes
  • Source modules will now correctly inherit clockDivider from subsystem pins
  • ModuleList.h files for layouts with CRUS will now include all necessary module classes
  • Fixed issue with clashing objectId's and unsaved inspector values when using multiple of the same CRUS
  • Sharing a CRUS with a user inspector will now work on any machine
  • Deleting a CRUS will now delete all relevant files
  • Added missing header files to installer to allow custom module creators to successfully compile
  • Fixed issue where modules would lose debug status if a module argument was changed
  • Changing arguments of a module will now result in the proper default values for new variables and arrays
  • Corrected how module variable steps are handled if they are beyond the allowable variable range
  • Now safely handling NaNs when entered in module variable values in the module properties window
  • Inspector values will no longer be corrupted if they are opened multiple times
  • Copying modules beyond the size of the canvas will no longer corrupt the canvas size
  • Corrected position of layout name on the canvas
  • Fixed awe_designer script so it no longer opens an unresponsive window if passing in an AWD
AWE Designer 8.D.1.1
2023-FEBRUARY-15
Enhancements
  • Improved error message clarity when modules are not found in an AWD
  • The Instance drop-down list on the canvas now correctly populates based on the connected multi-instance target when an AWD is opened
Bug Fixes
  • Fixed forward compatibility issue with loading AWJs
  • Fixed an issue with loading AWD's with subsystem modules set to Debug runtime status
  • Loading an AWD now restores all Subsystem module variable values
  • Fixed a possible crash related to the module alignment feature on canvas
  • Fixed a possible crash when using an .ini file with invalid characters or sections
  • Enabled the Permissions -> Allow Tuning feature on the right-click menu for Subsystems
  • When in tuning mode, the Paste Settings option now sends updated values to the target
  • Fixed invalid heap memory values for profiling results on multi-instance targets
  • Audio Start/Stop commands sent from AWE Server now support multi-instance targets
  • Deleting paramSet will now remove the "controlled by" variable element on the canvas
  • Router module now allows adjustments to the number of output channels
  • Fixed an issue with the BufferSourceInt32 array input being inappropriately rounded for large numbers
  • Image Inspector now correctly loads file paths that have been manually entered
  • Added header file to Pro installer to allow users to compile a subsystem module with flattenOnBuild=0
  • Corrected the default handling of complex data for modules while in Bypass mode
  • The Update Property feature now works for subsystem modules
  • Fixed VS projects included for the Example module pack
  • Fixed a bug that was ignoring case of module names and preventing wiring of modules
  • Fixed a problem with Postbuild ignoring modules marked for debug when built for release
  • The channel name defined inside a subsystem is no longer overwritten by the input channel name
AWE Designer 8.C.2.7
2022-DECEMBER-05
New Feature
Enhancements
  • New DSP Concepts logos implemented in the AWE Designer platform
  • Native target's fundamental block size can now be set by the user in AWE_Server.ini
  • Improvements to the Creating a User Inspector and Reusable Subsystems (RUS) sections of the AWE Designer User Guide
  • Module size is automatically reduced when the number of input pins is reduced
  • Module pin information is now saved in AWD files
Bug Fixes
  • Fixed an issue in the Designer canvas instance dropdown that prevented using more than 7 instances
  • Fixed an intermittent crash in Table module inspectors
  • Convert to Subsystem feature now creates pins in the order of the module positions on the canvas
  • Removed spurious error message from MATLAB console while using Convert to Subsystem feature
  • Fixed an issue with renaming subsystem pins
  • User Inspector Panels no longer change to a debug state when the subsystem is changed to debug
  • Updated AWJ's to save subsystem canvas size
  • Corrected the order in which coefficients are loaded from AWD's to fix an issue with Hilbert module and other subsystems
  • Corrected a problem with source modules not inheriting clockDividers correctly when copied from other layouts
  • Fixed a problem preventing the creation of feedback wires from arbitrary wires
  • Error dialogs no longer cut off text underneath the scroll bar
  • Fixed an issue with deleting or showing help for RUS in Standard and STMicro editions of Designer
  • Fixed an issue while creating RUS with object ID's assigned to subsystem modules
  • Corrected the implementation and usage of complex range input pins
  • Fixed generate_mfile MATLAB script script to support subsystems with layout variables
  • Fixed set_feedback_pinType MATLAB script to actually set the feedback type of the pin
AWE Designer 8.C.2.6
2022-SEPTEMBER-21
New Feature
  • Reusable Subsystems (RUS) can now be deleted using the right-click menu from within the module browser
Enhancements
  • Layout loading times have been improved by avoiding redundant operations
  • Flash File System maximum filename length increased to 56 chars
  • Invalid variable mask values (greater than 24) are no longer generated in ControlInterface.h files
  • Sink Properties modules have been updated to avoid warnings when rounding the sample rate
Bug Fixes
  • Fixed an issue that prevented some wav files from being fully processed
  • Fixed frequency domain plotting resolution of log x-axis in Sink Inspector
AWE Designer 8.C.2.5.A
2022-JULY-21
Bug Fixes
  • Fixed issue with coefficients not loading if array size is larger than default
  • Improved robustness of startup code to avoid crashes with corrupted persisted settings
  • Fixed custom inspectors so that they properly save and load settings
  • Fixed problem with missing modules in a layout not being fully deleted
2022-JULY-05
New Features
  • New Reusable Subsystem (RUS) feature can be used to generate shareable and portable subsystems using native Audio Weaver modules
  • New Interpreted Modules can be used to share custom made Audio Weaver modules with users of Standard Designer
Enhancements
  • Extended AWE Server USB proxy supports targets with more than one USB HID endpoint
  • Updated Module User's Guide to explain building of custom modules in Visual Studio in x86 mode
  • Improved error message when using Layout Variables with module variables instead of module arguments
  • Extended layout compile timeout to support very large layouts
  • Added more .awd example files to Examples/Module Usage
  • Results in Designer's profiling window are now cleared between RT and Manual Profiling runs
    AWD Example folder is now the default initial path when opening AWDs from the File menu
  • Feedback wire error now highlights module causing error
  • Profiling results now show the channel count of each module
Bug Fixes
  • Fixed issue where updated module paths were not persisting in Standard edition of Designer
  • Extended default timeout for flash erase commands sent to target to allow for long erase times
  • Fixed issue loading .awj files that contain measurement plots
  • Fixed issue where subsystems with Release modules were improperly marked as Debug and failed to build
  • Open All option on subsystems tab menu now works fully in runtime mode
  • Improved the robustness of AWE Server's audio device detection and loading to avoid crashes at startup
  • The search bar in Designer no longer searches through subsystem modules
  • Fixed possible audio glitch when using multi-rate modules and the buffer pool wire memory algorithm (beta)
  • Prevented users from changing protected subsystems and layouts by using keyboard shortcuts
  • Updated MATLAB scripts to more robustly detect if the target has floating point or fixed point modules
AWE Designer 8.C.2.4
2022-MAY-12
Enhancements
  • Native target updated to prevent audio processing from being interrupted by lower priority AWE tasks
  • Improved error reporting when surpassing the maximum number of channels on a wire
  • Updated profile_all_modulelibsto accept arbitrary block size (RT685 & Hexagon)
  • Changed default .csv names for module testing outputs for clarity
  • Improved formatting and clarity of saved .csv for peak profiling tool
  • Improved presentation of the Native audio preferences GUI
  • Improved module spacing and distribution capabilities in Designer
  • Validated Windows 11 compatibility
Bug Fixes (Modules)
  • Corrected build error when ParamSet modules are set to debug
  • All source modules now have empty clock divider when first created
  • Fixed error checking for modules to prevent building with input pins of differing sizes
Bug Fixes (Canvas)
  • Module variable values shown on canvas will now update when modified by User Inspectors
  • Feedback wire with inherited properties now succeeds without subsystem input pins
  • Changes to Layout Properties now prompt user to save layout
Bug Fixes (General)
  • AWJ files with empty subsystems now load successfully
  • Fixed failure for PFID_GetExtendedInfo when using SPI Tuning Interface
  • Fixed capitalization typo for AWECore header file in generated ModuleList.h files
  • Addressed issue with "Record File Name" textbox field in Layout Properties menu not always being editable
AWE Designer 8.C.2.3.A
2022-APRIL-15
New Feature
  • Removed Reusable Subsystem feature to allow for future incompatible improvements
2022-APRIL-6
New Features
  • AWE_Server Preferences menu added to expose common settings and options
  • Comm timeouts can now be specified in the Connect to Target menu in AWE_Server
  • Created Fract32 version of test_comm_speed
  • Added ability to select individual modules in system test menu
  • Added Version field to AWJ file
Enhancements
  • Improved speed of accessing module variables, resulting in faster layout build times
  • Improved and fixed issues with precision of floating-point numbers in Designer
  • Improved documentation of help file generation for reusable subsystems
  • Improved error message when two module libraries have a duplicate ClassName
  • Improved error message for non-existent layout variables
  • Improved error messages for User Inspector Controls with invalid modVar values
Bug Fixes (General)
  • The AWD file name no longer overwrites the record file path in the Designer Layout Properties menu
  • Ctrl-S shortcut functions properly while module inspector window is focused
  • Tuning Interface Test tool no longer causes Designer to freeze on failure
  • Fixed bug in feedback wires preventing previously saved AWD's from loading
  • Enabled renaming unconnected subsystem pins
  • Fixed issue with loading newly saved AWD's with subsystem modules in older versions of Designer
  • No longer calling prebuild when a variable is changed while the layout is running
  • Designer no longer freezes when running layout while module array has unapplied changes
  • AWJ files properly store measurement values
  • AWJ files with corrupted or invalid format display a useful error dialog
  • Multiline error windows will now have a scroll bar
  • Corrected baud rate setting for SPI proxies in AWE_Server
Bug Fixes (Interface)
  • "Edit accumulated delay" value is no longer obscured by vertical scroll bar
  • Disabled the "Use Audio file input" Manual Profiling option on embedded targets without a filesystem
  • Designer properly filters module browser on Multi-Instance targets
  • User Inspector Control correctly displays "controlled by" on canvas
  • Fixed flickering behavior of User Inspector Controls
  • Property view populated for User Inspector Control after navigating into subsystem
  • Opening a module inspector no longer closes the module property window
  • Help file is accessible in right click menu for reusable subsystem modules (RUS)
  • Dragging and dropping of a RUS onto an existing module in the module palette other than a RUS is no longer permitted
  • Enabled modifying values in "Array" tab of "Module Properties" when layout is protected
  • Space before = in String Annotations no longer gets deleted
  • Sink inspector successfully draws when in a subsystem and a member of an inspector group
Bug Fixes (Modules)
  • "Convert to Subsystem" on a subsystem with feedback wire completes without Designer freezing
  • Feedback wires propagate new thread ID info
  • Fixed buffer pool error for isolated modules with feedback wires
  • Feedback wire initial values propagate properly
  • Edit box User Inspector Control is usable with Wave File Sink modules
  • Fixed Meter User Inspector Control mapping property
  • Fixed User Inspector Controls attached to debug modules in release build causing Matlab errors
  • Creating User Inspector Control from a Sink module functions properly
  • Knob User Inspector Control properly handles step size with respect to max/min values
  • Sink inspector no longer displays signal at fixed sample rate of 48 kHz
  • Fixed and improved TableInterp and TableInterpXY modules
  • Designer no longer displays clockDivider in Wire Info box
  • Fixed issue preventing use of MeasurementV2 module inspector
AWE Designer 8.C.2.2
2022-JANUARY-7
New Features
  • New support for multiple sublayouts with the same clock divider to be generated in Designer, using BufferUp/Down V2 modules
  • Memory usage for each module and subsystem now shown on the canvas
  • New AWJ text based (json) file format can now be used to save Audio Weaver layouts
  • clockDivider is now a string instead of an integer in the Property Sheet
  • Modules controlled by a User Inspector Controls are now shown with dashed outlines
  • HTML doc files for reusable subsystems now have some fields automatically filled in
Enhancements
  • Internal updates significantly improve layout build times
  • Search bar in Designer will now return results for all subsystems in layout, not just opened subsystems
  • Closing MATLAB dialog now always returns topmost window back to Designer
  • The module property view is no longer closed when Running or Halting a layout
  • Module Tests results now show full hierarchical names for subsystems
  • Allowed Ctrl-S shortcut to work while modifying inspector dialogs
  • Improved help documentation for awe_module/process.m
Bug Fixes
  • Fixed an issue where array variables could be truncated when opening unbuildable system
  • Fixed bug in installer scripts that was preventing VS2010 redistributables from installing correctly
  • Corrected CPU overflow detection for the Native target
  • Fixed behavior where second instance of Designer was blocked after closing modal MATLAB window in first instance
  • Fixed issue with "Record File Name" text box not updating when auto-increment/specify is changed
  • Disabled custom module creator wizard menu in unsupportable Standard edition
  • profile_all_modulelibs script will now run even if Profiling folder does not already exist
  • Corrected display of grouping containers in Layout Properties dialog
  • Fixed bug where some modifications to the layout did not mark the system as 'dirty'
  • Sink inspector in subsystem now properly persists settings
  • Now properly persisting channel checkboxes in Sink Inspector
  • Control module count now correctly accounts for Subsystem Inspectors
  • Inspector groups now respect a module's "Allow Tuning" setting
  • Fixed undo and redo behavior for Convert to Subsystem feature
  • Fixed issue with Convert to Subsystem failing in MATLAB 2017b only
  • Accumulated delay now updates correctly in empty_subsystem module
  • Show Channel Names option no longer resets when navigating into subsystems
  • Fixed bug with channel names not fully propagating through subsystems
  • No longer rounding integer array values to 7 digits. Full 32 resolution now supported
  • Default clockDivider for source modules is now correctly
  • Fixed bug that did not allow module arguments to be the empty string
  • Fixed Vertical Alignment and Multiline options combo in canvas text box
