MultichannelMixerSmoothed
A smoothed mixer module with M outputs and N inputs
This time delay module has multiple input and multiple output channels. Smoothed delay can be applied at each intersections of the input and output lines. The delays and gains to be applied at each intersection comes from the control pin. Delays are specified in milliseconds and are in the range of [0 MAXDELAY].
At construction time, you specify the maximum delay (maxDelay) of the module. The variable, maxDelay determines the size of the internal state buffer. The size of the internal state buffer equals (maxDelay+1)*numChannels samples. The module applies smooth cross fading when delay or gain values are changed at run-time.
typedef struct _ModuleMultichannelMixerSmoothed
    FLOAT32 maxDelayTime;                         // Maximum delay, in milliseconds.
    FLOAT32 smoothingTimeDelay;                   // Time constant of the cross fading process of delay
    FLOAT32 smoothingTimeGain;                    // Time constant of the cross fading process of gain
    FLOAT32 smoothingCoeff;                       // Smoothing coefficient for cross fading of delays.
    FLOAT32 smoothingCoeffGain;                   // Smoothing coefficient for cross fading of gains.
    INT32 stateHeap;                              // Heap in which to allocate memory.
    INT32 maxDelay;                               // Max delay in samples.
    INT32* prevDelay;                             // Array holding previous delay values.
    INT32* currentDelay;                          // Array holding current delay values.
    FLOAT32* prevGain;                            // Array holding previous gain values.
    FLOAT32* currentGain;                         // Array holding current gain values.
    FLOAT32* oldGain;                             // Gain parameter for cross fading of delay.
    FLOAT32* newGain;                             // Gain parameter for cross fading of delay.
    INT32* fadingDone;                            // State variable to implement cross fading of delay.
    INT32* stateIndex;                            // Index of the oldest state variable in the array of state variables.
    FLOAT32* state;                               // State variable array.
} ModuleMultichannelMixerSmoothedClass;
Name
Type
Usage
isHidden
Default value
Range
Units
maxDelayTime
float
const
10
0:10
msec
smoothingTimeDelay
float
parameter
10
0:1000
msec
smoothingTimeGain
float
parameter
10
0:1000
msec
smoothingCoeff
float
derived
1
0.002081
Unrestricted
smoothingCoeffGain
float
derived
1
0.002081
Unrestricted
stateHeap
int
const
1
561
Unrestricted
maxDelay
int
const
1
480
Unrestricted
prevDelay
int*
state
1
[1 x 1]
Unrestricted
samples
currentDelay
int*
state
1
[1 x 1]
Unrestricted
samples
prevGain
float*
state
1
[1 x 1]
Unrestricted
samples
currentGain
float*
state
1
[1 x 1]
Unrestricted
samples
oldGain
float*
state
1
[1 x 1]
Unrestricted
newGain
float*
state
1
[1 x 1]
Unrestricted
fadingDone
int*
state
1
[1 x 1]
0:1
stateIndex
int*
state
1
[1 x 1]
Unrestricted
state
float*
state
1
[1 x 514]
Unrestricted
Description: audio input
Data type: float
Channel range: Unrestricted
Description: Control pin for MxN gain and delays
Data type: float
Description: Audio output
Data type: float
Scratch Pins
Channel count: 1
Block size: 32
Sample rate: 48000
Channel count: 1
Block size: 32
Sample rate: 48000
File Name: multichannel_mixer_smoothed_module.m
 M=multichannel_mixer_smoothed_module(NAME, NUMCHANNELS, MAXDELAY, MEMHEAP)
 Creates a multi-channel time delay in which the delay times are specified
 in milliseconds. The module has a multichannel input pin
 and an multichannel output pin. Each output channel is a delayed
 version of the corresponding input channel with different delay times
 for each channel. The module applies smooth transition between delay time
 changes.
 Arguments:
    NAME - name of the module.
    NUMCHANNELS - number of output channels for the module.
    MAXDELAY - maximum delay, in milliseconds.
    MEMHEAP - specifies the memory heap to use to allocate the main
         state buffer. This is a string and follows the memory allocation
         enumeration in Framework.h. Allowable values are:
            'AWE_HEAP_FAST' - always use internal DM memory.
            'AWE_HEAP_FASTB' - always use internal PM memory.
            'AWE_HEAP_SLOW' - always use external memory.
            'AWE_HEAP_FAST2SLOW' - use internal memory. If this fails
               then use external memory (the default).
            'AWE_HEAP_FASTB2SLOW' - use internal memory. If this fails
               then use external memory.
