AWE Core, AWE Core OS
2023-JUNE-2
New Features
  • Added support for HiFi Mini processors
  • New Mute Symmetric Module for matching fade-in/fade-out times
Enhancements
  • Updated documentation with Flash File System integration details
  • Improved accuracy when profiling Multi-Threaded and Multi-Instance integrations
  • Added Frequency Response feature to FIR Sparse module
  • Redesigned exponential functions for bit-exact matching between host and target module code
Bug Fixes
  • Fixed an issue with loading a Compiled Reusable Subsystem from a different folder path
  • Fixed an issue with building layouts containing a module with no input or output pins
  • Fixed the FIR Interpolator module's latency calculation
  • Fixed an issue with the Symmetric Scaler module's gradient calculation of negative numbers
  • Fixed an issue with loading saved parameters in BandToBin modules from AWJ layouts
  • Made allocation of memory for the Compiled Reusable Subsystem more flexible to avoid errors on memory limited systems
2023-FEBRUARY-15
New Features
  • New Peak Finder module for detecting multiple signal peaks in an audio block
  • New API function for loading AWBs from the Flash File System
Enhancements
  • Optimized performance of AWE Core's Audio Import/Export API functions
  • AWE Core will assume Single Heap functionality based on the number of heaps provided
Bug Fixes
  • Fixed broken image links in the AWE Core API documentation
  • Fixed an issue where saved values in the Mixer module were not being saved
  • Fixed an issue with multiple controlling modules accessing the same module
  • Fixed an issue where the ADSR module wouldn't release if triggered before sustain
  • Fixed AWE_Server crash when using certain ASIO device configurations
  • Fixed an issue with output data resolution in the PinkNoise module
  • Fixed an issue when opening UpFirDnConverter’s Inspector while running the layout
  • Fixed an internal memory leak in AWECoreOS
2022-DECEMBER-05
New Features
Enhancements
  • Reduced build error for simultaneous ParamSet accesses to a warning message
  • Added support for multicore AWECore instances on the same hardware core
  • Introduced option for memory bounds checking on array access commands
  • Users no longer need to provide BUILD64 when compiling for 64-bit targets
Bug Fixes
  • Fixed regression test failure for the Biquad Sparse V6 module
  • Fixed issue where the Inspector would not update Mixer V3's mix table
  • Fixed issue where the SoftClipFract32 Inspector would not display the correct gain
2022-SEPTEMBER-21
New Features
  • Added support for Arm® Cortex™-M55 and Ethos™-U55 processors
  • Created new Null Source module for advanced wire routing
Enhancements
  • Corrected awe_audioGetPumpMask's return value for an overflowed layout
  • Supported number of input/output channels has been increased from 64 to 255v
  • ParamSet can now access unsigned integer variables
  • Added check to prevent multiple ParamSet modules from accessing the same variable
  • Flash File System minimum filename length increased to 56 chars
Bug Fix
  • Fixed an issue that could cause audio artifacts with certain biquad filters
2022-July-21
Bug Fixes
  • Removed unnecessary memory allocations while instantiating modules
  • Fixed Sink inspector to work after changes in Designer
2022-July-05
New Features
Enhancements
  • Expanded Audio Weaver Core API to selectively control profiling
  • Added check that Buffer Down module does not clock divide faster than allowed
  • Improved error reporting when changing frequencies with Graphic Equalizer module
  • Added "Resonant" filter option to all Second Order Filter modules
Bug Fixes
  • Fixed issue where unchecked maxTaps values could cause crashes in certain filter modules
  • Fixed issue where StatusSet module sent stale data upon initialization
  • Fixed issue where certain subsystem modules would not appear in the Module Tests dialog window
  • Fixed issue where some Biquad Sparse modules would not display the names of the filterType argument
  • Fixed issue where the incorrect Router Smoothed module inspectors would appear if there was more than 16 channels
2022-MAY-12
New Feature
  • Created TableSourceV2 module to support multichannel outputs and indexing
Enhancements
  • Improved test coverage, reporting, and performance for multiple modules
  • All Scaler modules now have consistent triangle icons in module browser
Bug Fixes
  • SetWireProperties module now properly protects against negative arguments
  • Tablesource module updated to propagate correct sample rate
2022-APRIL-6
New Features
  • New UpFIRDnConverter module allows for efficient sample rate conversions for non-integer ratios
  • New SOFControlV3 adds option to choose between Direct Form 1 or 2 implementations for biquads
  • AWECoreOS: new API to return ID's of internal threads, allowing application to set CPU affinity per thread
  • Added support for TI C66xx builds
Enhancements
  • Module constructors now have access to the calling AWEInstance struct
  • Made several TableInterp and TableInterpXY module fixes and improvements
  • MultichannelMixerSmoothed module now checks for control input pin being a valid size
  • Made robustness and performance improvements to WaveFileSource and WaveFileSink modules
  • Improved error message for invalid values for BufferDown module
  • Usage improvements made to the SOFControl module variables and range checking
  • Improved performance of the hold feature in SbAttackRelease module for fast attack times
  • Improved output channel names for the WhiteNoise module
  • MATLAB add_argument function now documented
  • If enabled, the profiling report will now print size of Wire Buffer Pool
Bug Fixes
  • Fixed null pointer access when modules failed to allocate sufficient memory in constructor
  • Fixed bug in White Noise module not sending random generator seed value to target
  • BufferUpV2 and BufferDownV2 modules updated to reject invalid buffer up/down factors
  • The SampleAndHold module now has consistent behavior
  • Corrected the latency calculation of the Downsampler module
  • Example AWD file Mixing_Console_Example.awd now uses a relative audio path
  • Updated some tests to run successfully on Hexagon targets
2022-JANUARY-7
New Features
  • New BufferUpV2 and BufferDownV2 modules allow multiple sublayouts with the same clock divider to be generated
  • New module FilterBankFIRNChan allows for efficient implementation of long FIRs with different coefficients per channel
Enhancements
  • TableInterpRuntime module is no longer deprecated
  • Improved organization and architecture for AWECore header files
  • SetWireProperties now returns a clearer error message in the prebuild function
Bug Fixes
  • Updated common modules to pass regression tests on fixed point targets
  • Fixed smoothing sync issue across all channels in ThreeBandToneControl module, float and fract32 versions
  • test_triggered_file_sink_rt.m now completes even if MATLAB working directory is "c:"
  • Fixed test_system_variable_rt.m to pass in Native mode
  • PinkNoise module updated to pass system level test
  • Updated RunningMinMax to have the correct type of momentary reset control
  • Deleted buggy Fractional delay float and fract32 modules. Use v2 versions instead (float and fract32)
  • Corrected MuteSyncFract32 browser name
  • Object ID now properly populated for wire buffers
  • Fixed memory access violation on certain 64-bit build systems
  • Corrected awe_audioIsStarted function documentation
  • Added missing documentation for virtual modules, like marker, annotations, etc.
