SecondOrderFilterSmoothedCascade
filterType=1, Linear gain. [gain].
filterType=16, 1st order Bessel low pass filter. [freq].
typedef struct _ModuleSecondOrderFilterSmoothedCascade
    INT32 numStages;                              // Number of cascaded stages of the second order filter.
    FLOAT32 smoothingTime;                        // Time constant of the smoothing process.
    INT32 updateActive;                           // Specifies whether the filter coefficients are updating (=1) or fixed (=0).
    FLOAT32 smoothingCoeff;                       // Smoothing coefficient. This is computed based on the smoothingTime, sample rate, and block size of the module.
    INT32* filterType;                            // Selects the type of filter that is implemented by the module: Bypass=0, Gain=1, Butter1stLPF=2, Butter2ndLPF=3, Butter1stHPF=4, Butter2ndHPF=5, Allpass1st=6, Allpass2nd=7, Shelf2ndLow=8, Shelf2ndLowQ=9, Shelf2ndHigh=10, Shelf2ndHighQ=11, PeakEQ=12, Notch=13, Bandpass=14, Bessel1stLPF=15, Bessel1stHPF=16, AsymShelf1stLow=17, AsymShelf1stHigh=18, SymShelf1stLow=19, SymShelf1stHigh=20, VariableQLPF=21, VariableQHPF=22.
    FLOAT32* freq;                                // Cutoff frequency of the filter, in Hz.
    FLOAT32* gain;                                // Amount of boost or cut to apply, in dB if applicable.
    FLOAT32* Q;                                   // Specifies the Q of the filter, if applicable.
    FLOAT32* targetCoeffs;                        // Matrix of filter target coefficients. The size of the matrix is 5 x numStages. Each column contains the variables for a biquad arranged as [b0; b1; b2; a1; a2].
    FLOAT32* currentCoeffs;                       // Matrix of filter current coefficients. The size of the matrix is 5 x numStages. Each column contains the variables for a biquad arranged as [b0; b1; b2; a1; a2].
    FLOAT32* state;                               // State variables. 2*numChannels per section.
} ModuleSecondOrderFilterSmoothedCascadeClass;
Name
Type
Usage
isHidden
Default value
Range
Units
numStages
int
const
2
1:1:32
smoothingTime
float
parameter
10
0:1:1000
msec
updateActive
int
parameter
1
1
0:1
smoothingCoeff
float
derived
1
0.06449
Unrestricted
filterType
int*
parameter
[1 x 2]
0:22
freq
float*
parameter
[1 x 2]
10:0.1:23990
Hz
gain
float*
parameter
[1 x 2]
-24:0.1:24
dB
Q
float*
parameter
[1 x 2]
0:0.1:20
targetCoeffs
float*
derived
[5 x 2]
Unrestricted
currentCoeffs
float*
state
[5 x 2]
Unrestricted
state
float*
state
1
[2 x 2]
Unrestricted
Description: audio input
Data type: float
Channel range: Unrestricted
Description: audio output
Data type: float
File Name: second_order_filter_cascade_module.m
 M=second_order_filter_cascade_module(NAME, ISSMOOTH, NUMSTAGES)
 of coefficients.
 Arguments:
    NAME - name of the module.
