AllpassDelay16
![](../../__attachments/2907242629/image-20230125-192435.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
![](../../__attachments/2907242629/image-20230125-192520.png?inst-v=afeb83b1-861e-46b8-b4de-1c642321bb7f)
The filter has a constant magnitude response of 1.0 and a non-zero phase response. The filter has a DC gain of 1.0.
MAXDELAY specifies the size of the delay buffer. At run-time, you can vary the delay in the range 0 to MAXDELAY as well as the coefficient . The third argument OUTPUTSTATE is a Boolean which specifies whether the module has an optional 2nd output pin. The 2nd output pin gets the output of the delay buffer as shown above.
Both modules operate on mono data only.
typedef struct _ModuleAllpassDelay16
 INT32* state; // State variable array
} ModuleAllpassDelay16Class;
state | int* | state | 1 | [51 x 1] | Unrestricted |
Description: audio input
Data type: float
Channel range: Unrestricted
Description: audio output
Data type: float
Data type: float
File Name: allpass_delay16_module.m
M = allpass_delay16_module(NAME, MAXDELAY, OUTPUTSTATE)
Delay based allpass (1st order), using integer length delay. This
module uses 16-bit internal state variables in order to save on
memory. Arguments:
NAME - name of the module.
OUTPUTSTATE = 0.
