AWE Designer
AWE Designer 8.D.2.1
2023-SEPTEMBER-18
New Features
Enhancements
Bug Fixes
AWE Designer 8.D.1.3
2023-JULY-21
Enhancements
Bug Fixes
AWE Designer 8.D.1.2
2023-JUNE-2
Enhancements
Bug Fixes
AWE Designer 8.D.1.1
2023-FEBRUARY-15
Enhancements
Bug Fixes
AWE Designer 8.C.2.7
2022-DECEMBER-05
New Feature
Enhancements
Bug Fixes
Fixed
AWE Designer 8.C.2.6
2022-SEPTEMBER-21
New Feature
Enhancements
Bug Fixes
AWE Designer 8.C.2.5.A
2022-JULY-21
Bug Fixes
2022-JULY-05
New Features
Enhancements
Bug Fixes
AWE Designer 8.C.2.4
2022-MAY-12
Enhancements
Updated
Bug Fixes (Modules)
Bug Fixes (Canvas)
Bug Fixes (General)
Fixed failure for
AWE Designer 8.C.2.3.A
2022-APRIL-15
New Feature
2022-APRIL-6
New Features
Enhancements
modVarvalues
Bug Fixes (General)
Bug Fixes (Interface)
Bug Fixes (Modules)
Designer no longer displays
AWE Designer 8.C.2.2
2022-JANUARY-7
New Features
Enhancements
Bug Fixes
Default
