Danville_ADC_Filter
ADC Filter Control
This module controls the ADC filters implemented in the target. Please refer to the accompanying documentation of the target hardware Note that if user selects an unsupported value, target will use default value instead. The default value field gives users to enter a one time initialization value for this module instance. Clicking the overrride checkbox allows user to use a value entered via inspector.
typedef struct _ModuleDanville_ADC_Filter
    INT32 ADC_Filter_Val;                         // ADC Filter Value
    INT32 ADC_Filter_Default_Val;                 // ADC Filter Default Value
    INT32 ADC_Filter_OLD_Val;                     // ADC OLD Filter Value
    INT32 ADC_Filter_Override;                    // ADC Filter Override
} ModuleDanville_ADC_FilterClass;
Name
Type
Usage
isHidden
Default value
Range
Units
ADC_Filter_Val
int
parameter
0:15
int
parameter
0:15
ADC_Filter_OLD_Val
int
parameter
0:15
ADC_Filter_Override
int
parameter
0:1
File Name: Danville_ADC_Filter.m
 M=DanvilleADCFilter_module(NAME, HASINPUTPIN)
 Copyright 2016.   Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
 $Revision: 1.1 $
 Set default input arguments
