Danville_DAC_AKM_SQ
DAC Sound Quality Control
This module controls the AKM DAC Sound Quality Mode Settings.
typedef struct _ModuleDanville_DAC_AKM_SQ
    INT32 DAC_SQ_Val;                             // DAC Sound Quality Mode Value
    INT32 DAC_SQ_Default_Val;                     // DAC Sound Quality Mode Default Value
    INT32 DAC_SQ_OLD_Val;                         // DAC Sound Quality Mode OLD Value
    INT32 DAC_SQ_Override;                        // DAC Sound Quality Override
} ModuleDanville_DAC_AKM_SQClass;
Name
Type
Usage
isHidden
Default value
Range
Units
DAC_SQ_Val
int
parameter
0:7
DAC_SQ_Default_Val
int
parameter
0:7
DAC_SQ_OLD_Val
int
parameter
0:7
DAC_SQ_Override
int
parameter
0:1
File Name: Danville_DAC_AKM_SQ.m
 M=DanvilleDACFilter_module(NAME, HASINPUTPIN)
 Copyright 2016.   Danville Signal Processing, Inc. All Rights Reserved.
                   written for AK 4495
 Author:  E. Enrique
 $Revision: 1.1 $
 Set default input arguments
