Danville_Digital_In
Digital Input Control
This module takes a value from the target hardware and outputs the value to wards the Audio Weaver Canvass Please refer to the accompanying documentation of the target hardware Locator values serves as an ID which associates the module to information coming from a preassigned hardware trigger Clicking the overrride checkbox allows user to use a value via the inspector while the value from the target hardware is ignored.
typedef struct _ModuleDanville_Digital_In
    INT32 Digital_In_Val;                         // Digital In Value
    INT32 Digital_In_Locator;                     // Digital In Locator
    INT32 Digital_In_Override;                    // Digital In Override
} ModuleDanville_Digital_InClass;
Name
Type
Usage
isHidden
Default value
Range
Units
Digital_In_Val
int
parameter
0:65535
Digital_In_Locator
int
parameter
0:31
Digital_In_Override
int
parameter
0:1
Description: Switch Bit
Data type: int
File Name: Danville_Digital_In.m
function M=Danville_Digital_In_module(NAME)
 Copyright 2016.  Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
 $Revision: 1.1 $
