SubblockStatisticsFract32
Computes statistics at several points in a block of samples
This module calculates statistics of the input signal at several points for each block. Output blocks have samples, where each output sample is the statistics value for a subblock The input pin can have an arbitrary number of interleaved channels and the calculation occurs over all channels. The output pin has a single channel and a blockSize equal to floor(inputBlocksize / subblockSize)
For each subblock, one of the following values is calculated: maximum, minimum, maximum absolute value, mean, RMS, standard deviation, variance, or average energy. The parameter statisticsType specifies which statistic is computed: 0=maximum, 1=minimum, 2=maximum absolute value, 3=mean, 4=RMS, 5=standard deviation, 6=variance, 7=average energy, 8=sum, 9=sum of squares. The module is stateless and the statistic is recomputed for each block.
typedef struct _ModuleSubblockStatisticsFract32
    INT32 subblockSize;                           // Number of samples per subblock to run statistics on.
    INT32 statisticsType;                         // Type of statistics calculated.
    INT32 nSubblocks;                             // Number of subblocks per input block.
} ModuleSubblockStatisticsFract32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
subblockSize
int
const
2
Unrestricted
statisticsType
int
parameter
0:9
nSubblocks
int
state
16
Unrestricted
Description: Audio input
Data type: fract32
Channel range: Unrestricted
Description: Value
Data type: fract32
File Name: subblock_statistics_fract32_module.m
 M = subblock_statistics_fract32_module(NAME, SUBSIZE)
 This module calculates statistics of the input signal, outputting one
 sample per SUBSIZE input samples.  The statisticsType parameter controls
 what function is computed, e.g., min or max.
 Arguments:
    NAME - name of the module.
    SUBSIZE - The number of samples per subblock to run statistics on
 Copyright 2008-2014 DSP Concepts, Inc.  All Rights Reserved.
