LogicCompareConstReplaceInt32
Compares input with a user definable value with option to replace the output
This module implements a general purpose logical compare module against stored user defined integer values that is capable of realizing many different logic operations. The behavior of the logic compare is controlled by the compareType parameter. compareType is an integer in the range from 0 to 5 inclusive.
The following table discusses the various compare oprations types and which variables are active in each case:
compareType = 0, performs logic equal operation.
compareType = 1, performs logic not equal operation.
compareType = 2, performs logic less than operation.
compareType = 3, performs logic less than equal operation.
compareType = 4, performs logic greater than operation.
compareType = 5, performs logic greater than equal operation.
If logic condition is true: replace output by user definable value (replacementValue).
If logic condition is false: copy value from input to output.
Module works on multichannel control signals, with individual parameters for each channel. No smoothing is applied when switching the output to or from the replacementValue.
typedef struct _ModuleLogicCompareConstReplaceInt32
    INT32 numChan;                                // Number of channels.
    INT32* compareType;                           // Selects the type of comparison that is implemented by the module: Equal=0 NotEqual=1 LessThan=2 LessOrEqual=3 GreaterThan=4 GreaterOrEqual=5. One row per comparison.
    INT32* constValue;                            // Selects value against to compare against.
    INT32* replaceValue;                          // Selects value for replacement.
} ModuleLogicCompareConstReplaceInt32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
numChan
int
const
1
1
Unrestricted
compareType
int*
parameter
[1 x 1]
0:5
constValue
int*
parameter
[1 x 1]
Unrestricted
replaceValue
int*
parameter
[1 x 1]
Unrestricted
Description: Control In
Data type: int
Channel range: Unrestricted
Block size range: 1
Description: Control Out
Data type: int
File Name: logic_compare_const_replace_module.m
 M=logic_compare_const_replace_int_module(NAME)
 Compares input with a user definable value (constValue)
 If condition is true: replace output by user definable value (replacementValue)
 If condition is false: copy value on input to output
 Arguments:
    NAME - name of the module.
 Copyright 2023.  DSP Concepts, Inc.  All Rights Reserved.
