OggVorbisOneShotPlayerRAM
Triggered playback of OggVorbis encoded files
This module outputs OggVorbis data triggered via an input pin. The input .trigger is a Boolean value which starts the playback upon rising edge. Playback continues until the end of the file and does not repeat before the next trigger. Retrigger while being in the middle of the playback has no effect and will be ignored. Changing the filename while being in the middle of the playback will stop the playback.
The module supports multichannel such that, if the ogg file has less channels than output pin channels, then the remaining output channels will be muted. If the ogg file has more channels than the output pin channels it will be handled as an error.
If the modules arguments samplerate does not match the samplerate of the OggVorbis file it will be handled as an error.
typedef struct _ModuleOggVorbisOneShotPlayerRAM
    ModuleInstanceDescriptor instance;            // Common Audio Weaver module instance structure
    INT32 playCtrl;                               // Play/Pause control. 1 for play (default), 0 for pause
    INT32 seekPosTime;                            // Seek position in seconds
    INT32 seekPosSamples;                         // Seek position in samples
    INT32 oggLength;                              // Number of samples in currently loaded file
    INT32 triggerPrev;                            // State trigger signal to determine rising edge
    INT32 triggerLatched;                         // State trigger denoting player is active
    INT32 totalDuration;                          // Total duration of the stream in seconds
    INT32 totalSamples;                           // Total number of samples
    INT32 samplesRemaining;                       // Samples remaining in the stream
    INT32 timeRemaining;                          // Remaining time for playback in milliseconds
    INT32 prevSeekPosTime;                        // Seek position in seconds
    INT32 prevSeekPosSamples;                     // Seek position in samples
    INT32 isReady;                                // Boolean that indicates the module is not ready to output data
    INT32 sampleRate;                             // Sample rate
    UINT32 pinID;                                 // Specifies which control pins are available.
    INT32 oggSR;                                  // Actual sample rate of the ogg file.
    INT32 oggNumChannels;                         // Number of channels in the ogg file.
    INT32 decoderLock;                            // Flag for synchronization between the set and process function
    INT32 syncLock;                               // Flag for synchronization between the set and process function
    INT32 oggBufferSize;                          // Size of the buffer containing the Ogg Vorbis stream
    INT32 memPoolHeapSize;                        // Size of memory pool heap
    INT32 memPoolScratchSize;                     // Size of memory pool scratch
    INT32 usedMemPoolHeapSize;                    // Used size memory pool heap
    INT32 usedMemPoolScratchSize;                 // Used size memory pool scratch
    UINT32* oggBuffer;                            // OggFile transferred from PC to target DSP via this buffer.
    INT32* memPoolHeap;                           // Memory pool heap for ogg decoder
    INT32* memPoolScratch;                        // Memory pool scratch for ogg decoder
    INT32* oggHandle;                             // OggVorbis library instance
    INT32* oggBufferPos;                          // Structure variable holding the buffer management variables
} ModuleOggVorbisOneShotPlayerRAMClass;
Name
Type
Usage
isHidden
Default value
Range
Units
playCtrl
int
parameter
1
Unrestricted
seekPosTime
int
parameter
Unrestricted
Seconds
seekPosSamples
int
parameter
Unrestricted
Samples
oggLength
int
derived
Unrestricted
triggerPrev
int
state
Unrestricted
triggerLatched
int
state
Unrestricted
totalDuration
int
state
Unrestricted
Seconds
totalSamples
int
state
Unrestricted
samplesRemaining
int
state
Unrestricted
timeRemaining
int
state
Unrestricted
ms
prevSeekPosTime
int
state
Unrestricted
Seconds
prevSeekPosSamples
int
state
Unrestricted
samples
isReady
int
state
Unrestricted
sampleRate
int
const
1
48000
Unrestricted
pinID
uint
const
1
1
Unrestricted
oggSR
int
derived
1
Unrestricted
oggNumChannels
int
derived
1
Unrestricted
decoderLock
int
state
1
Unrestricted
syncLock
int
state
1
Unrestricted
oggBufferSize
int
state
1
Unrestricted
memPoolHeapSize
int
state
1
192000
Unrestricted
memPoolScratchSize
int
state
1
12800
Unrestricted
usedMemPoolHeapSize
int
state
1
Unrestricted
bytes
int
state
1
Unrestricted
bytes
oggBuffer
uint*
parameter
1
[0 x 0]
Unrestricted
memPoolHeap
int*
state
1
[192000 x 1]
Unrestricted
memPoolScratch
int*
state
1
[12800 x 1]
Unrestricted
oggHandle
INT32*
state
1
Unrestricted
oggBufferPos
INT32*
state
1
Unrestricted
Description: boolean trigger signal
Data type: int
Channel range: 1
Block size range: 1
Description: output data
Data type: fract32
Description: playing state
Data type: int
Scratch Pins
Channel count: 1
Block size: 256
Sample rate: 48000
File Name: ogg_vorbis_oneshot_player_ram_module.m
