SecondOrderFilterSmoothed
General 2nd order filter designer with smoothing
This module implements a general purpose second order filter that is capable of realizing many different filter types. The module performs internal smoothing allowing the filters to be updated without introducing clicks. In all cases, the module implements an underlying second order filter. First order filters are realized by setting some of the second order coefficients to zero.
filterType=16, 1st order Bessel high pass filter. [freq].
filterType=23, 2nd order Resonant bandpass filter. [freq, Q].
typedef struct _ModuleSecondOrderFilterSmoothed
    INT32 filterType;                             // Selects the type of filter that is implemented by the module: Bypass=0, Gain=1, Butter1stLPF=2, Butter2ndLPF=3, Butter1stHPF=4, Butter2ndHPF=5, Allpass1st=6, Allpass2nd=7, Shelf2ndLow=8, Shelf2ndLowQ=9, Shelf2ndHigh=10, Shelf2ndHighQ=11, PeakEQ=12, Notch=13, Bandpass=14, Bessel1stLPF=15, Bessel1stHPF=16, AsymShelf1stLow=17, AsymShelf1stHigh=18, SymShelf1stLow=19, SymShelf1stHigh=20, VariableQLPF=21, VariableQHPF=22 Resonant=23.
    FLOAT32 freq;                                 // Cutoff frequency of the filter, in Hz.
    FLOAT32 gain;                                 // Amount of boost or cut to apply, in dB if applicable.
    FLOAT32 Q;                                    // Specifies the Q of the filter, if applicable.
    FLOAT32 smoothingTime;                        // Time constant of the smoothing process.
    INT32 updateActive;                           // Specifies whether the filter coefficients are updating (=1) or fixed (=0).
    FLOAT32 b0;                                   // Desired first numerator coefficient.
    FLOAT32 b1;                                   // Desired second numerator coefficient.
    FLOAT32 b2;                                   // Desired third numerator coefficient.
    FLOAT32 a1;                                   // Desired second denominator coefficient.
    FLOAT32 a2;                                   // Desired third denominator coefficient.
    FLOAT32 current_b0;                           // Instantaneous first numerator coefficient.
    FLOAT32 current_b1;                           // Instantaneous second numerator coefficient.
    FLOAT32 current_b2;                           // Instantaneous third numerator coefficient.
    FLOAT32 current_a1;                           // Instantaneous second denominator coefficient.
    FLOAT32 current_a2;                           // Instantaneous third denominator coefficient.
    FLOAT32 smoothingCoeff;                       // Smoothing coefficient. This is computed based on the smoothingTime, sample rate, and block size of the module.
    FLOAT32* state;                               // State variables. 2 per channel.
} ModuleSecondOrderFilterSmoothedClass;
Name
Type
Usage
isHidden
Default value
Range
Units
filterType
int
parameter
0:23
freq
float
parameter
250
10:0.1:20000
Hz
gain
float
parameter
-24:0.1:24
dB
Q
float
parameter
1
0:0.1:20
smoothingTime
float
parameter
10
0:1:1000
msec
updateActive
int
parameter
1
1
0:1
b0
float
derived
1
1
Unrestricted
b1
float
derived
1
Unrestricted
b2
float
derived
1
Unrestricted
a1
float
derived
1
Unrestricted
a2
float
derived
1
Unrestricted
current_b0
float
state
1
1
Unrestricted
current_b1
float
state
1
Unrestricted
current_b2
float
state
1
Unrestricted
current_a1
float
state
1
Unrestricted
current_a2
float
state
1
Unrestricted
smoothingCoeff
float
derived
1
0.06449
Unrestricted
state
float*
state
1
[2 x 1]
Unrestricted
Description: audio input
Data type: float
Channel range: Unrestricted
Description: audio output
Data type: float
File Name: second_order_filter_module.m
 M=second_order_filter_module(NAME)
 of standard filter types. The filter operates on multiple interleaved
 coefficients.
 Arguments:
    NAME - name of the module.
