AWE Designer
AWE Designer 8.D.2.6
2024-AUGUST-15
New Features
Designer will now show error messages for invalid layouts when pressing Propagate Changes
Enhancements
Improved license authentication robustness for users who cannot access DSPC web license server
Updated AWD/AWJ formats to no longer require prebuilding layouts while loading
Made various internal improvements to improve layout build and load times
Updated JSON engine used internally for processing .json data for speed improvement
Added a warning for users when saving layout with newer AWD/AWJ version
Improved error reporting when attempting to generate a ModuleList.h file with an invalid layout name
Improved module I/O information included in profiling data
Bug Fixes
StatusSet execution order now behaves correctly for subsystem target module
Now preventing excessive get_module_state messages when using subsystem inspectors
No longer listing duplicate module classes in the missing module list dialog
Updated CRUS generation to throw error if using a ChangeThread module
Fixing build of some layouts using feedback wires across multiple subsystems
Deleting a module will no longer throw cryptic error messages if unrelated modules are not configured correctly
Corrected issue with stale clockDividers in Source modules when switching between single and multi-instance targets
Fixed issue in Native target where sample rate info from audio device was not being propagated to layouts
Improved robustness of renaming user inspector panels
Corrected handling of empty schema versions in CRUSs, and excluded pointer variable types from CRUS manifests
Fixed deleting CRUS/RUS from the module browser in the Standard edition
AWE Designer 8.D.2.5
2024-JUNE-29
New Features
Reduced load and save times for AWJ files, and updated AWJ version to 3.0
Added option in Layout Properties menu to force bind_wire commands to happen before other wire allocations
Added options in Generate Target Files menu to select target instanceID and to include a Lookup Table in the generated .awb/.aws
Added support for Multi-Instance in Module Tests tool
Added support for Multi-Instance and Multi-Canvas in the Tuning Interface Test tool
The minimum MATLAB version required for using Pro editions of Designer has been updated from R2017b to R2021b
Designer is no longer tested with MATLAB R2017b, so using this version may result in inconsistent or faulty behavior
Enhancements
Improved the validation of AWJ files against a custom JSON schemas
BuildFlash.exe tool now warns user when filenames are truncated due to length limitations
Bug Fixes
Fixed issue with building Multi-Canvas layouts when different instances have different block sizes
Improved error detection and message clarity for invalid subsystems with only a virtual module between input and output
Ensuring that correct target information is available in profiling after doing attach to running target
Fixed issue that was preventing layouts saved with invalid paths in ParamSet module from being loaded
Execution order for Param Set and Status Set style modules can now target modules in subsystems
Fixed issue where the 'controlled by' field for modules on the canvas was not always being updated
Removed support in Designer for module argument inputs beginning with '0b'
Fixed issue where module argument strings starting with '0x' were being improperly converted to decimal values
Fixed issue in Designer when running on Multi-Instance target with more than 16 instances
Updated AWE Server Flash Manager to be able to access different Flash File Systems on Multi-Instance or Multi-Canvas target
Loading and saving module arrays from file now maintains full precision
Fixing corruption in layout file after running process files
Fixing user inspector operability after running manual profiling
Fixed a number of issues that could cause Tuning Interface Test to hang, and improved flexibility of modules required to run the test
Fixed issue where copying an invalid subsystem to a new layout could corrupt the layout
Convert to Subsystem will now retain custom objectIDs for modules
Failed attempts of Convert to Subsystem now correctly restores original subsystem
Designer now throws a warning if the output HW pin is not fract32
Restored the right click Help option for RUS/CRUS on the canvas
test_start_audioMATLAB function in the case of Multi-Instance targetsFixed issue when loading layouts with out-of-sync module control information
AWE Designer 8.D.2.4
2024-MARCH-15
New Features
Updated AWJ version to 2.1 to reduce overall file size
Enhancements
Revamped MATLAB AWE framework by adopting more efficient implementation, resulting in faster build and load times
AWE objects are now passed as handles, instead of copied-by-assignment
Existing user scripts may not be compatible if they rely on assignments creating new objects. To address this, update scripts to explicitly call the 'copy' function (see Updating MATLAB User Scripts to 8.D.2.4/8.D.2.5+ for more details)
Standard edition is now built using MATLAB 2023b (requires MCR version 2023b Update 3)
CRUS modules now support controlling internal variables with ParamSet modules
Added calculated layout block rate in profiling results, in addition to existing measured time per process
Added information in AWE_Server about heap alignment words for the attached target
Plot Frequency Response now uses different colors for each channel
Improved robustness when loading corrupted .awd's
Bug Fixes
Updated peak profiling tool to always plot last value and to support clockDividers >= 10
Fixed support for CRUS that include MATLAB subsystem modules
Copy pasting a RUS will now always control the correct User Inspector
ObjectID's can now be updated for modules even if layout can't be built
Prevented users from updating module arguments while a layout is running
Fixed Example module pack's VS project
Corrected AWJ saving of any font size used in Annotation modules
Fixed canvas labels for all subsystem types for User Inspector values
Subsystem canvas labels are no longer shown in raw double precision
Prevented unnecessary ModuleList.h files from being generated for multi-canvas targets
AWE Designer 8.D.2.3
2024-JANUARY-26
New Features
Created a Feedback Settings module that enables setting feedback wire properties using Layout Variables
Enhancements
Added 'Hierarchy Level' column in exported profiling reports
Allow RUS to be loaded from folders that contain a comma in the name
Improvements to layout build times:
Removed module runtime status from Subsystem canvas text
Improved build time progress bar redraw performance
Removed unnecessary redraw when building
Removed extraneous target reads when redrawing canvas after completed builds
Removed obsolete functionality in generate_version. Function now always returns -1
Removed extraneous target queries messages when building layouts
Bug Fixes
Fixed Attach to Running Target for Multi-Canvas applications
Fixed profiling percentage calculations in Multi-Rate, Multi-Instance systems
Fixed Push Button User Inspector for Multi-Instance systems
Made update to avoid unnecessary target queries for read-only Checkbox User Inspectors
Removed test-only code that could cause system to become unstable in case of a test failure
Added 'extern "C"' to generated InitAWB.h files to improve C++ application support
Improved the canvas text for Reusable Subsystems
Removed newline from canvas text when module status is not Active
Fixed peak profiling not working with multi-instance targets when active instances are not consecutive
Fixed using a semi-colon separated list of variables to be controlled via one user inspector
Note that you cannot use variables in different instances with one user inspector, they must all be on the same instance
An error notifying the user of this will only show if you open the user inspector after building and running the layout
Fixed creation of layouts using subLayoutIds for non-multi-instance targets
AWE Designer 8.D.2.2
2023-NOVEMBER-8
New Features
Module documentation and Designer User's Guides are now hosted on DSP Concepts website
Enhancements
CPU load per core is now displayed in AWE_Server if target has defined core affinities
CPU overflows in AWE_Server now calculated correctly for layouts running across multiple cores (SMP)
Bug Fixes
Module properties window will no longer close when a layout is run
Matlab will now force values to be within min/max range set by the module variable or array
Fixed failure with virtual modules in feedback wire path
Fixed issue with module compatibility with previously saved AWJs
Fixed loading of AWD's that contain subsystems with no input or output pin
Fixed propagation of accumulated delay through subsystems
Update AWE_Server to do deferred processing on all Native instances, not just instance 0
AWE Designer 8.D.2.1
2023-SEPTEMBER-18
New Features
Enhancements
Bug Fixes
AWE Designer 8.D.1.3
2023-JULY-21
Enhancements
Bug Fixes
AWE Designer 8.D.1.2
2023-JUNE-2
Enhancements
Bug Fixes
AWE Designer 8.D.1.1
2023-FEBRUARY-15
Enhancements
Bug Fixes
AWE Designer 8.C.2.7
2022-DECEMBER-05
New Feature
Enhancements
Bug Fixes
Fixed
AWE Designer 8.C.2.6
2022-SEPTEMBER-21
New Feature
Enhancements
Bug Fixes
AWE Designer 8.C.2.5.A
2022-JULY-21
Bug Fixes
2022-JULY-05
New Features
Enhancements
Bug Fixes
AWE Designer 8.C.2.4
2022-MAY-12
Enhancements
Updated
Bug Fixes (Modules)
Bug Fixes (Canvas)
Bug Fixes (General)
Fixed failure for
AWE Designer 8.C.2.3.A
2022-APRIL-15
New Feature
2022-APRIL-6
New Features
Enhancements
modVarvalues
Bug Fixes (General)
Bug Fixes (Interface)
Bug Fixes (Modules)
Designer no longer displays
AWE Designer 8.C.2.2
2022-JANUARY-7
New Features
Enhancements
Bug Fixes
Default
