OggVorbisOneShotPlayerFFS
Triggered playback of OggVorbis encoded files
This module outputs OggVorbis data triggered via an input pin. It extracts compressed audio data from AWE Flash File System container on control input pin "fsInstance" dependent on "fileName" argument. User can also change the file name directly inside "fileName" array as 32-bit packed data (char) during run time.
The input .trigger is a Boolean value which starts the playback upon rising edge. Playback continues until the end of the file and does not repeat before the next trigger. Retrigger while being in the middle of the playback has no effect and will be ignored. Changing the filename while being in the middle of the playback will stop the playback.
The module supports multichannel such that, if the ogg file has less channels than output pin channels, then the remaining output channels will be muted. If the ogg file has more channels than the output pin channels it will be handled as an error.
If the modules arguments samplerate does not match the samplerate of the OggVorbis file it will be handled as an error.
If any errors occurs in the module, it is captured in the parameter .errorCodes. Please check in Errors.h for the meaning of error code returned.
typedef struct _ModuleOggVorbisOneShotPlayerFFS
INT32 playCtrl; // Play/Pause control. 1 for play (default), 0 for pause
INT32 seekPosTime; // Seek position in seconds
INT32 seekPosSamples; // Seek position in samples
INT32 oggLength; // Number of samples in currently loaded file
INT32 triggerPrev; // State trigger signal to determine rising edge
INT32 triggerLatched; // State trigger denoting player is active
INT32 totalDuration; // Total duration of the stream in seconds
INT32 totalSamples; // Total number of samples
INT32 samplesRemaining; // Samples remaining in the stream
INT32 timeRemaining; // Remaining time for playback in milliseconds
INT32 prevSeekPosTime; // Seek position in seconds
INT32 prevSeekPosSamples; // Seek position in samples
INT32 fsInstance; // AWE flash file system instance pointer
INT32 errorCode; // Captures errors that could arise in the module C code. Appears on the inspector
INT32 isReady; // Boolean that indicates the module is not ready to output data
INT32 waitForMuteDone; // Internal flag to check if the smooth mute is done
INT32 sampleRate; // Sample rate
UINT32 pinID; // Specifies which control pins are available.
INT32 oggSR; // Actual sample rate of the ogg file.
INT32 oggNumChannels; // Number of channels in the ogg file.
INT32 decoderLock; // Flag for synchronization between the set and process function
INT32 syncLock; // Flag for synchronization between the set and process function
INT32 memPoolHeapSize; // Size of memory pool heap
INT32 memPoolScratchSize; // Size of memory pool scratch
INT32 usedMemPoolHeapSize; // Used size memory pool heap
INT32 usedMemPoolScratchSize; // Used size memory pool scratch
INT32* fileName; // Name of wave file to playback
INT32* fileNamePrev; // Previous wave file name
INT32* oggHandle; // OggVorbis library instance
INT32* oggBufferPos; // Structure variable holding the buffer management variables
INT32* memPoolHeap; // Memory pool heap for ogg decoder
INT32* memPoolScratch; // Memory pool scratch for ogg decoder
void * muteModPtr; // Internal pointer to mute module to mute before reconfiguration
void * unMuteModPtr; // Internal pointer to mute module to unmute after reconfiguration
UINT32 * fsInstancePtr; // AWE flash file system instance pointer
UINT32 * oggBuffer; // State variable holds the start address of the wave file in filesystem.
} ModuleOggVorbisOneShotPlayerFFSClass;
playCtrl | int | parameter | 0 | 1 | Unrestricted | |
seekPosTime | int | parameter | 0 | 0 | Unrestricted | Seconds |
seekPosSamples | int | parameter | 0 | 0 | Unrestricted | Samples |
oggLength | int | derived | 0 | 0 | Unrestricted | |
triggerPrev | int | state | 0 | 0 | Unrestricted | |
triggerLatched | int | state | 0 | 0 | Unrestricted | |
totalDuration | int | state | 0 | 0 | Unrestricted | Seconds |
totalSamples | int | state | 0 | 0 | Unrestricted | |
samplesRemaining | int | state | 0 | 0 | Unrestricted | |
timeRemaining | int | state | 0 | 0 | Unrestricted | ms |
prevSeekPosTime | int | state | 0 | 0 | Unrestricted | Seconds |
prevSeekPosSamples | int | state | 0 | 0 | Unrestricted | samples |
fsInstance | int | state | 0 | 0 | Unrestricted | |
errorCode | int | state | 0 | 0 | Unrestricted | |
isReady | int | state | 0 | 0 | Unrestricted | |
waitForMuteDone | int | state | 0 | 0 | Unrestricted | |
sampleRate | int | const | 1 | 48000 | Unrestricted | |
pinID | uint | const | 1 | 1 | Unrestricted | |
oggSR | int | derived | 1 | 0 | Unrestricted | |
oggNumChannels | int | derived | 1 | 0 | Unrestricted | |
decoderLock | int | state | 1 | 0 | Unrestricted | |
syncLock | int | state | 1 | 0 | Unrestricted | |
memPoolHeapSize | int | state | 1 | 192000 | Unrestricted | |
memPoolScratchSize | int | state | 1 | 12800 | Unrestricted | |
usedMemPoolHeapSize | int | state | 1 | 0 | Unrestricted | bytes |
usedMemPoolScratchSize | int | state | 1 | 0 | Unrestricted | bytes |
fileName | int* | parameter | 0 | [14 x 1] | Unrestricted | |
fileNamePrev | int* | state | 1 | [14 x 1] | Unrestricted | |
oggHandle | int* | state | 1 | [182 x 1] | Unrestricted | |
oggBufferPos | int* | state | 1 | [8 x 1] | Unrestricted | |
memPoolHeap | int* | state | 1 | [192000 x 1] | Unrestricted | |
memPoolScratch | int* | state | 1 | [12800 x 1] | Unrestricted | |
muteModPtr | void * | state | 1 | 0 | Unrestricted | |
unMuteModPtr | void * | state | 1 | 0 | Unrestricted | |
fsInstancePtr | UINT32 * | state | 1 | Unrestricted | ||
oggBuffer | UINT32 * | state | 1 | Unrestricted |
Description: boolean trigger signal
Data type: int
Channel range: 1
Block size range: 1
Description: AWE file system instance pointer
Data type: int
Channel range: Unrestricted
Block size range: 1
Description: output data
Data type: fract32
Description: playing state
Data type: int
Scratch Pins
Channel count: 1
Block size: 256
Sample rate: 48000
File Name: ogg_vorbis_oneshot_player_ffs_module.m
