WaveLoopPlayerFlashFract32
Periodic WAV playback supporting pitch shifting
This module outputs wave data in fract32 fixed-point format in loop mode. It extracts wave data from AWE Flash File System container on the target Flash device, based on WAVFILE argument. User has to specify the file name as an argument and can also change file name directly into fileName array as 32-bit packed data during run time. Along with the above parameters, the playback functionality can be enabled from the control input pin, 1 - Enable and 0 - Disable.
The module supports multichannel such that, if the wave file has more channels than provided to the module argument then only channels up to output pin will be used. If the wave file has less channels than output pin channels, then the remaining output channels will be muted.
If any errors occurs in the module, it is captured in the parameter .errorCodes. Please check in Errors.h for the meaning of error code returned.
On windows (Native PC) or Linux platforms, file operations are used and make sure the file path exists in the Audio Weaver file search path. If not, please update the file serch path from File->Set File Search Path... in the Designer. Maximum absolute file path should not be more than 512 charecters.
typedef struct _ModuleWaveLoopPlayerFlashFract32
    ModuleInstanceDescriptor instance;            // Common Audio Weaver module instance structure
    INT32 smoothingTime;                          // Time constant of the pitch smoothing process
    INT32 smoothingFactor;                        // Update rate for smoothing coeffs (per block)
    INT32 startDelay;                             // Starting delay value in samples
    INT32 enable;                                 // En/Disable playback. Resets sample position to startDelay value upon stop
    FLOAT32 normRate;                             // Rate of data used to compute the ratio for normalized players
    FLOAT32 maxRate;                              // Highest allowed rate of playback that can be specified
    INT32 NCOFracBits;                            // Number of least-significant bits for the *fractional* part of the NCO word (word size: 32)
    INT32 maxWaveChannels;                        // Maximum number of channels a wave file can have
    INT32 waveLength;                             // Number of samples in currently loaded file
    INT32 fIndex;                                 // Current index in the wave file
    FLOAT32 fIndexFract;                          // Current fract index in the wave file
    INT32 errorCode;                              // Captures errors that could arise in the module C code. Appears on the inspector
    INT32 isReady;                                // Boolean that indicates the module is not ready to output data
    INT32 waitForMuteDone;                        // Internal flag to check if the smooth mute is done
    FLOAT32 currentFStep;                         // Current (smoothed) rate at which audio is read from the input buffer
    INT32 waveSR;                                 // Actual sample rate of the wave file.
    INT32 waveNumChannels;                        // Number of channels in the wave file.
    INT32 waveBit;                                // Wave data sample bit resolution.
    FLOAT32 scaleFactor;                          // Scale factor for playback rate
    FLOAT32 smoothingCoeff;                       // Smoothing (pitch) coefficient
    INT32 NCOIntBits;                             // Number of most-significant bits for the *integer* part of the NCO word (word size: 32). By default: 20 bits
    FLOAT32 formatF;                              // Integer value of left-shift by NCOFracBits. Determines the precision of the linear interpolation.
    FLOAT32 formatI;                              // Integer value of left-shift by NCOIntBits. Determines the maximum playback rate and the maximum size of a wave file in samples.
    INT32 decFactor;                              // Internal derived variable to hold decimated smoothing blocks
    INT32 waveBuffer;                             // State variable holds the start ofset of the wave file in flash file system.
    UINT32 pinID;                                 // Specifies which control pins are available.
    INT32* fileName;                              // Name of wave file to playback
    INT32* fileNamePrev;                          // Name of wave file to playback
    void * muteModPtr;                            // Internal pointer to mute module to mute before reconfiguration
    void * unMuteModPtr;                          // Internal pointer to mute module to unmute after reconfiguration
    void * localWaveBuffer;                       // Internal pointer used only on Windows or Linux, which holds entire wave data
} ModuleWaveLoopPlayerFlashFract32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
smoothingTime
int
parameter
10
0:1000
msec
smoothingFactor
int
parameter
4
1:512
startDelay
int
parameter
Unrestricted
enable
int
state
1
0:1
normRate
float
const
1
Unrestricted
maxRate
float
const
2
Unrestricted
NCOFracBits
int
const
12
Unrestricted
maxWaveChannels
int
const
10
Unrestricted
waveLength
int
derived
Unrestricted
fIndex
int
state
Unrestricted
fIndexFract
float
state
Unrestricted
errorCode
int
state
Unrestricted
isReady
int
state
Unrestricted
waitForMuteDone
int
state
Unrestricted
currentFStep
float
state
1
Unrestricted
waveSR
int
derived
1
Unrestricted
waveNumChannels
int
derived
1
Unrestricted
waveBit
int
derived
1
Unrestricted
scaleFactor
float
derived
1
1
Unrestricted
smoothingCoeff
float
derived
1
Unrestricted
NCOIntBits
int
derived
1
20
Unrestricted
formatF
float
derived
1
Unrestricted
formatI
float
derived
1
Unrestricted
decFactor
int
derived
1
1
Unrestricted
waveBuffer
int
state
1
Unrestricted
pinID
uint
const
1
3
Unrestricted
fileName
int*
parameter
1
[14 x 1]
Unrestricted
fileNamePrev
int*
state
1
[14 x 1]
Unrestricted
muteModPtr
void *
state
1
Unrestricted
unMuteModPtr
void *
state
1
Unrestricted
localWaveBuffer
void *
state
1
Unrestricted
         Description: Flag to enable playback
           Data type: int
       Channel range: 1
    Block size range: 1
           Data type: float
       Channel range: 1
    Block size range: 1
         Description: output data
           Data type: fract32
         Description: playing state
           Data type: int
Scratch Pins
       Channel count: 10
          Block size: 261
         Sample rate: 48000
File Name: wave_loop_player_flash_fract32_module.m
