Danville_DIR_Active
DIR Active Status
This module reflects the validity of the DIR (Digital Input Receiver) stream coming from the SHARC DSP. If value is set to 1 means a valid signal. A value of zero means a signal does not exist or not locking. No available overrride for this feature.
typedef struct _ModuleDanville_DIR_Active
INT32 DIR_Active_Val; // DIR Active Value
} ModuleDanville_DIR_ActiveClass;
DIR_Active_Val | int | state | 0 | 0 | 0:1 |
Description: DIR Active Bit
Data type: int
File Name: Danville_DIR_Active.m
M=Danville_DIR_Active_module(NAME, HASINPUTPIN)
Author: E. Enrique
$Revision: 1.1 $
