Danville_Source_Select
Source Select Control
This module allows users to select an input signal source. Please refer to the accompanying documentation of the target hardware Note that if user selects an unsupported value, target will use default value instead. The default value field gives users to enter a one time initialization value for this module instance. Clicking the overrride checkbox allows user to use a value entered via inspector.
typedef struct _ModuleDanville_Source_Select
    INT32 Source_Select_Val;                      // Source Select Value
    INT32 Source_Select_Default_Val;              // Source Select Default Value
    INT32 Source_Select_OLD_Val;                  // Source Select OLD Value
    INT32 Source_Select_Override;                 // Source Select Override
} ModuleDanville_Source_SelectClass;
Name
Type
Usage
isHidden
Default value
Range
Units
Source_Select_Val
int
parameter
0:31
int
parameter
0:31
int
parameter
0:31
int
parameter
0:1
Description: Source Select
Data type: int
File Name: Danville_Source_Select.m
 M=Danville_Source_Select_module(NAME)
 Copyright 2016.   Danville Signal Processing, Inc. All Rights Reserved.
 Author:  E. Enrique
 $Revision: 1.1 $
