ThreeBandToneControlFract32
Three band equalizer
This module implements a three band tone control fixed point module. Low shelf filter is used for low frequency band with normalised gain with respect to mid band gain. Similarly for high frequency band high shelf filter is used with normalised gain with respect to mid gain. Finally scale smoothely the entire signal with mid band gain.
typedef struct _ModuleThreeBandToneControlFract32
    FLOAT32 lowFreq;                              // Low band center frequency, in Hz
    FLOAT32 midFreq;                              // Mid band center frequency, in Hz
    FLOAT32 highFreq;                             // High band center frequency, in Hz
    FLOAT32 lowGain;                              // Low band gain, in dB
    FLOAT32 midGain;                              // Mid band gain, in dB
    FLOAT32 highGain;                             // High band gain, in dB
    INT32 headRoomBits;                           // Head room bits. This prevents internal clipping in the filter stages
    INT32 postShift;                              // postShift controls the headroom within the fixed-point filtering
    FLOAT32 twoPowMinusPostShift;                 // Two power -postShift value
    INT32 filterUpdateActive;                     // Boolean that is set when updating coefficients
    fract32 smoothingCoeff;                       // Smoothing coefficient for the filter coefficients
    fract32 midTargetGain;                        // Target gain of the mid frequency gain
    fract32 midCurrentGain;                       // Current gain of the mid frequency gain
    fract32 midSmoothingCoeff;                    // Sample-by-sample smoothing coefficient of the mid frequency gain
    fract32* lowerTargetCoeffs;                   // Target coefficients for the low frequency shelf
    fract32* lowerCurrentCoeffs;                  // Current coefficients for the low frequency shelf
    fract32* lowerState;                          // State variables for the low frequency shelf
    fract32* upperTargetCoeffs;                   // Target coefficients for the high frequency shelf
    fract32* upperCurrentCoeffs;                  // Current coefficients for the high frequency shelf
    fract32* upperState;                          // State variables for the high frequency shelf
} ModuleThreeBandToneControlFract32Class;
Name
Type
Usage
isHidden
Default value
Range
Units
smoothingTime
float
parameter
20
0:1000
msec
lowFreq
float
parameter
60
30:200
Hz
midFreq
float
parameter
600
200:4000
Hz
highFreq
float
parameter
6000
4000:20000
Hz
lowGain
float
parameter
-12:12
dB
midGain
float
parameter
-12:12
dB
highGain
float
parameter
-12:12
dB
headRoomBits
int
parameter
1
2
Unrestricted
postShift
int
parameter
1
5
Unrestricted
float
parameter
1
0.03125
Unrestricted
filterUpdateActive
int
parameter
1
1
Unrestricted
smoothingCoeff
fract32
parameter
1
0.03278
Unrestricted
midTargetGain
fract32
parameter
1
0.03125
Unrestricted
midCurrentGain
fract32
parameter
1
0.03125
Unrestricted
midSmoothingCoeff
fract32
parameter
1
0.001041
Unrestricted
lowerTargetCoeffs
fract32*
parameter
1
[5 x 1]
Unrestricted
lowerCurrentCoeffs
fract32*
parameter
1
[5 x 1]
Unrestricted
lowerState
fract32*
state
1
[4 x 1]
Unrestricted
upperTargetCoeffs
fract32*
parameter
1
[5 x 1]
Unrestricted
upperCurrentCoeffs
fract32*
parameter
1
[5 x 1]
Unrestricted
upperState
fract32*
state
1
[4 x 1]
Unrestricted
Description: audio input
Data type: fract32
Channel range: Unrestricted
Description: audio output
Data type: fract32
Scratch Pins
Channel count: 1
Block size: 32
Sample rate: 48000
File Name: three_band_tone_control_fract32_module.m
 M=three_band_tone_control_fract32_module(NAME)
 Implements a three band tone control module.
 Arguments:
    NAME - name of the module.
