WaveOneShotPlayerRAMFract32
One-shot Wave Player supporting pitch shifting
This module outputs wave data triggered via an input pin. The input .trigger is a Boolean value which if set starts playback. Playback continues until the end of the file is reached and then it stops. Retrigger while being in the middle of the playback has no effect and will be ignored. The module supports multichannel such that, if the wave file has more channels than provided to the module argument then only channels up to output pin channels will be used. If the wave file has less channels than output pin channels, then the remaining output channels will be muted.
typedef struct _ModuleWaveOneShotPlayerRAMFract32
INT32 smoothingTime; // Time constant of the pitch smoothing process
INT32 smoothingFactor; // Update rate for smoothing coeffs (per block)
FLOAT32 normRate; // Rate of data used to compute the ratio for normalized players
FLOAT32 maxRate; // Highest allowed rate of playback that can be specified
INT32 NCOFracBits; // Number of least-significant bits for the *fractional* part of the NCO word (word size: 32)
INT32 waveLength; // Number of samples in currently loaded file
INT32 fIndex; // Current index in the wave file
FLOAT32 currentFStep; // Current (smoothed) rate at which audio is read from the input buffer
INT32 triggerPrev; // State trigger signal to determine rising edge
INT32 triggerLatched; // State trigger denoting player is active
INT32 waveSR; // Actual sample rate of the wave file.
INT32 waveNumChannels; // Number of channels in the wave file.
FLOAT32 scaleFactor; // Scale factor for playback rate
FLOAT32 smoothingCoeff; // Smoothing (pitch) coefficient
INT32 NCOIntBits; // Number of most-significant bits for the *integer* part of the NCO word (word size: 32). By default: 20 bits
FLOAT32 formatF; // Integer value of left-shift by NCOFracBits. Determines the precision of the linear interpolation.
FLOAT32 formatI; // Integer value of left-shift by NCOIntBits. Determines the maximum playback rate and the maximum size of a wave file in samples.
UINT32 pinID; // Specifies which control pins are available.
INT32* waveBuffer; // Data transferred from PC to target DSP via this buffer.
} ModuleWaveOneShotPlayerRAMFract32Class;
smoothingTime | int | parameter | 0 | 10 | 0:1000 | msec |
smoothingFactor | int | parameter | 0 | 4 | 1:512 | |
normRate | float | const | 0 | 1 | Unrestricted | |
maxRate | float | const | 0 | 2 | Unrestricted | |
NCOFracBits | int | const | 0 | 12 | Unrestricted | |
waveLength | int | derived | 0 | 100400 | Unrestricted | |
fIndex | int | state | 0 | 0 | Unrestricted | |
currentFStep | float | state | 0 | 1 | Unrestricted | |
triggerPrev | int | state | 0 | 0 | Unrestricted | |
triggerLatched | int | state | 0 | 0 | Unrestricted | |
waveSR | int | derived | 1 | 48000 | Unrestricted | |
waveNumChannels | int | derived | 1 | 1 | Unrestricted | |
scaleFactor | float | derived | 1 | 1 | Unrestricted | |
smoothingCoeff | float | derived | 1 | 0.1248 | Unrestricted | |
NCOIntBits | int | derived | 1 | 20 | Unrestricted | |
formatF | float | derived | 1 | 4096 | Unrestricted | |
formatI | float | derived | 1 | 524300 | Unrestricted | |
pinID | uint | const | 1 | 1 | Unrestricted | |
waveBuffer | int* | parameter | 0 | [50209 x 1] | Unrestricted |
Data type: int
Channel range: 1
Block size range: 1
Data type: float
Channel range: 1
Block size range: 1
Description: output data
Data type: fract32
Description: playing state
Data type: int
File Name: wave_oneshot_player_ram_fract32_module.m
