AWE Core, AWE Core OS
AWECore 8.D.13, AWECoreOS 8.B.23
2026-Feb-9
New Features
Added a new optional callback in AWEInstance which is called post destroy from the AWECore. Targets can use this callback to free any resources outside Audio Weaver
New modules, FIRV2 and FIRNChanV2 were added with a support for hardware accelerators selection, if available
Added a new ProfileThread module to support profiling of threads running outside of the Audio Weaver in a custom module
Added a new AlignmentDelay module. This module will align multiple input pins to have same delay at the output
Added subcanvas feature with new modules: Subcanvas, SubcanvasParamGet, SubcanvasParamSet, SubcanvasArrayGet and SubcanvasArraySet
Added support to access module arguments in the M.arg.varName format
Added a new MemoryLoadingV2 module with support to select a heap name and a run time control to switch between reading and writing. This module can now run on the shared heap memory
Enhancements
Added more logs in AWECore for debug purposes
Updated SystemVariable module to provide information of the layout (thread) in which the module is running. Previously, it always provided the primary layout info regardless of the thread it was running in
Added support for a maximum of 32 threads per instance. Previously, there was a limit of a maximum of 15 threads per instance
Added more validation to the module access functions to avoid invalid operations
Improved AWB loading time
Bug Fixes
Fixed a potential bug of corrupted status on the control pin in the ActivationMuteControl module
Fixed a bug in the server tuning proxies when reading a file from the target flash file system. The server no longer crashes when reading a file from the target flash file system
Fixed a bug in extracting the file name in awe_loadAWBfromFlash
Undeprecated the interleaved sink module, which is useful for the Subcanvas feature ArrayGet
Fixed issues with shared bit fields in AWECore flags to make them thread safe
Fixed a bug in the server when connected to a target while it is booting. The server now fails gracefully if the target is not ready
Updated the RMS module inspector text to indicate the value is in dB units
Improved file search ability in Native targets
Fixed a bug in the multi-instance Native target where the latency between two instances was not constant
Fixed a bug in creating a lookup table with correct size to store layout objects
Updated WaveFileSink and WaveFileSource modules to handle underflow/overflows more efficiently
Fixed an issue in loading AWB from the flash when the layout contains multiple flash based wave players
Fixed a SoftClip module inspector issue with currentGain. It is now displayed as a meter instead of a slider
Fixed issues with the deferred processing of modules in CRUS. No module will miss deferred processing now
Fixed a bug in the SbSmooth module when a custom window type is selected
Fixed a bug in the DelayNChanV2 module maxDelay parameter usage. The maximum delay setting is now an argument in the module
Updated Modulelist.h generation to avoid dependency on other header files
Fixed a bug in AWECore where the audio pump failed to start after an overflow occurred and a reset happened under certain conditions
AWECore 8.D.12, AWECoreOS 8.B.22
2025-Jun-30
New Features
Added support for fract16 wires, and created fract16 Source and Sink modules. Also updated TypeConvert, Interleave and Deinterleave to support fract16 inputs/outputs
New ScalerNSymmetricFadingN module supports per-channel fading times
New ParamGetV2 module will use correct mask value when calling module Get function
Added detection and clean recovery in case of an instance crashing in multi-instance systems. This includes the new ChangeThreadV2 module
New callback to forward tuning packets in multi-instance systems. Can be used rather than polling
Added a new API to check if all instances are started or not in a multi-instance system
Added support for loading module packs dynamically by creating a linked list of module tables. Also added AWEPlugin library to help with loading libraries on target
Enhancements
Added ability to attenuate the tone level in the evaluation timeout beeps
Improved the accuracy of coefficient calculations for Biquad HP (high precision) modules
Bug Fixes
Fixed potential crash in AWECoreOS when lifetimes of multiple instances do not overlap
Fixed memory corruption issue with AWECoreOS logging callbacks while loading AWBs
Improved the implementation of some reference applications to have cleaner shutdowns
Fixed a crash issue on SMP systems using multi-instance that don't support TLS keyword
Fixed an issue with profiling being incorrect on multi-instance targets when tuning master instance is > 0
Added support for correctly profiling memory usage for modules that allocate memory in Set functions
Corrected sampleRate calculation in SweepGen module when the triggerPin argument is true
Fixed an audio glitch in MuteLinearFade module when quickly changing the gain value
Updated CRUS to support modules that use flash file system
Refactored Meter module for improved performance on some targets
Improved module documentation for Source and Sink modules
Fixed biquad module documentation to differentiate between Bessel high pass and low pass filter types
Added clarity to coefficient ordering in the SbComplexFIR module documentation
AWECore 8.D.11, AWECoreOS 8.B.21
2025-MARCH
New Features
New BiquadCascadeV2 and SecondOrderFilterSmoothedCascadeV3 provide additional control over biquad processing, including DF1 and TDF2 forms
New ActivationMute module safely activates and deactivates modules and subsystems. Expands ActivationMux module by allowing targeted modules and subsystems to be at any hierarchy level
Created new ShiftBits module that supports logical and arithmetic shifts, and int32 and fract32 inputs
Added support for reset functions in modules, and created an API to trigger reset of the entire layout
Added support for peak profiling for modules rather than average. Also added more control to existing profiling options with API awe_setProfilingOptions
Enhancements
When pointer module variables are set during module construction, the module Set function is now called with the mask set to the pointer variable
Improved heap allocation algorithm to save between 1-10% memory usage
Updated modules with potentially wide inspectors to split them into multiple rows for better visibility
Modules that require file systems will now still load and run on bare metal targets, but will not do any processing
Updated MaxAbs module to improve performance on some targets
Bug Fixes
Updated some module prebuild error messages to provide more clarity
AWECore 8.D.10, AWECoreOS 8.B.20
2024-DECEMBER-
New Features
Updated AWE Core multi-instance implementation to support Progressive Loading for Early Audio use cases
Added an API that can be called from modules to return the parent layout's index
New logging callbacks added in AWE Core to provide log messages to user application
New Event module can trigger new event callbacks on the target system
New AGCAttackHoldRelease implements a new AGC with additional control parameters
New PeriodicFuncGen module implements an efficient table-lookup based wave generator
New BufferSourceV2 modules add flexibility, including option to store the data as interleaved or deinterleaved buffer
New ParamSetV2 module adds support for variable mask in deferred set calls
New ActivationMux module can be used to safely control changing status of multiple subsystems
New MuteNSymmteric module adds per channel control to MuteSymmetric module
New RebufferedSink module combines a rebuffer module and a sink module, which can greatly reduce memory and CPU usage
Enhancements
Improved reliability and usability of WaveFileSink module
Updated ParamSetTableV2 to always rewrite values when the array is updated, even if index is unchanged
Added support for M55 targets that do not support Helium
Updated DelayMixerSmoothed module code to protect against negative delays
Improved performance of Router in certain configurations
Bug Fixes
Updated DelayStateWriter to fix potential issues in FIRReader modules
Fixed Biquad module to work with 12 or more channels
Fixed issue with AGCLimiterCoreV2 when saved in AWJ files
Fixed crash in FilterbankFIR modules that could happen if module failed during construction
Fixed potential memory leak when loading AWBs from file on Linux targets
Fixed issues with AWECoreOS tuning logging and packetBufferSize configuration option
Fixed SystemVariable module to get system information from current layout when appropriate
Updated BiquadLoading module to avoid potential small differences between input and output
Updated Subtract module to fail builds if input pin is not float
No longer overwriting internal parameter ranges for BiquadSparseV5/6 modules during prebuild
Fixed integer display issues in module .html documentation
Corrected reply length of PFID_FetchValue in Tuning Syntax documentation
Fixed issue with synchronization resets on multi-instance targets with > 2 instances with different base clock dividers
AWECore 8.D.9, AWECoreOS 8.B.19
2024-AUGUST-15
New Features
New Constant DC Source module that enables users to control module variables with Layout Arguments
Added support for Cortex-M55, SHARC-FX, and Kalimba targets
New AGC Core V2 Fract32 module that allows for more gain using Q8.24 output format
Added new
PFID_GetAllMatchingModulesfor returning the objectIDs of all modules in a layout that match the provided classID
Enhancements
Overflows are now measured per instance, and profiling corrects for time lost to preemption
Improved AWE Core Integration Guide with troubleshooting tips
Created new icons for the ChangeThread module
Bug Fixes
Fixed crash when checking the heaps on an invalid instance
Fixed issue in AWE_Server where heap usage would not appear when loading an AWB from flash memory
AWECore 8.D.8, AWECoreOS 8.B.18
2024-JUNE-10
New Features
New Conditional Replace module to deterministically replace the output with a constant value
New API function awe_getBuildVersionInfo returns library build and version information
New Change Thread module to buffer data to any specified target instance and/or thread
Enhancements
Updated Flash File System API functionality for valid pointers
Updated PFID_GetProfileValues' documentation for the correct datatype of the reply values
Updated documentation to clarify that Control API can only access the active core's instances
Updated documentation to clarify that Preemption API can be called by any instance shared by the same core
Bug Fixes
Fixed AWE_Server's Flash Manager tool to access multi-instance target files
Fixed regression test failure for WetDry, SecondOrderFilter, and SecondOrderFilterCascade modules
Improved reliability of CrossoverFilter module's regression test
Fixed issue where Mute Symmetric module could audio "pop" if driven by a Param Set in deferred update mode
Fixed Module System Test failure for Wave File Source modules
Fixed issue where FilterbankFIRNChan modules weren't calling destroy for internal FFT modules
Fixed issue when loading a layout on multi-instance targets that shared Packet and Reply buffer memory
AWECore 8.D.7, AWECoreOS 8.B.17
2024-MARCH-15
New Features
New Scaler Symmetric Fading V2 module that enables external control of the gain value
New ClipAsymInt32 module that performs Asymmetric Clipping for integer values
New PFID_GetProfileValuesPreCalc message to support consistent profiling across irregular pump calls
New AWE Core API Callbacks to capture audio interrupts for accurate profiling
Enhancements
AWE Core can now allocate memory aligned up to 128 words
Added support to run Module Regression Tests on Multi-Instance targets
Added Frequency Response functionality to Biquad Sparse V6 module
Allow users to adjust Compiled Reusable Subsystem parameters with ParamSet
Added optional support to control scalar values with ArraySet
Bug Fixes
Fixed crash when loading certain AWB files containing Flash-based Wave Player modules
Updated user documentation with more details on the SPI Tuning Protocol
Fixed issue when instantiating Compiled Reusable Subsystems that control variables in nested subsystems
Fixed default range of ClipAsymFract32 to (-1, 1)
Fixed issue in module documentation that incorrectly stated that gain filter type uses linear units
Fixed issue where BiquadLoading modules were using First Order implementations on some targets
Fixed regression test failures for the following modules:
BufferDownV2
BufferUpV2
CycleBurnerSet
MeasureSampleRate
MultichannelMixerSmoothed
SystemVariable
FileStreaming
AWECore 8.D.6, AWECoreOS 8.B.16
2024-JANUARY-26
New Features
Added support for QNX-based targets
New API that supports multirate processing on different instances
New 8 channel biquad VectorLib function for certain filter modules
Enhancements
Updated default channel names for some modules
Fixed issue with stale coefficients in subsystem by forcing recalculation during prebuild
Reduced the duration of certain module regression tests
Improved robustness of IPC buffers against multi-instance synchronization issues
IPCBuffer subsystem can now set Clock Divider and sublayout Thread ID
Bug Fixes
Fixed issue when controlling WaveFileSink with another module
Fixed regression tests for Delay Reader modules
Fixed issue where Audio Start/Stop callbacks weren't being called on secondary instances
Fixed typo that affected building for 64-bit targets
Fixed issue where overflows on secondary instances could halt primary instance
2023-NOVEMBER-8
New Features
New FIR Reader module allows users to share state betwen multiple FIR filter modules
New GraphicEQFract32V2 module that adds frequency array to previous version
Enhancements
Updated AWE Core OS architecture to reduce audio dropouts during extended deferred processing
Controlling modules (ArraySet, ParamGet, ParamSet, ParamSetTableV2, StatusSetV2) can now specify when to execute relative to the module being controlled
Allow loading .awb's on non-multi-instance targets, even if the .awb instance ID does not align with the target's instance ID
Bug Fixes
Fixed an issue when loading Compiled Reusable Subsystems on multi-instance targets
2023-SEPTEMBER-18
New Features
Enhancements
Bug Fixes
2023-JULY-21
Enhancements
Bug Fixes
2023-JUNE-2
New Features
Enhancements
Bug Fixes
2023-FEBRUARY-15
New Features
Enhancements
Bug Fixes
2022-DECEMBER-05
New Features
Enhancements
Bug Fixes
2022-SEPTEMBER-21
New Features
Enhancements
Bug Fix
2022-July-21
Bug Fixes
2022-July-05
New Features
Enhancements
Bug Fixes
Fixed issue where unchecked
2022-MAY-12
New Feature
Enhancements
Bug Fixes
2022-APRIL-6
New Features
Enhancements
MATLAB
Bug Fixes
2022-JANUARY-7
New Features
Enhancements
Bug Fixes
Corrected
