AWE Core, AWE Core OS
AWECore 8.D.6, AWECoreOS 8.B.16
2024-JANUARY-26
New Features
Added support for QNX-based targets
New API that supports multirate processing on different instances
New 8 channel biquad VectorLib function for certain filter modules
Enhancements
Updated default channel names for some modules
Fixed issue with stale coefficients in subsystem by forcing recalculation during prebuild
Reduced the duration of certain module regression tests
Improved robustness of IPC buffers against multi-instance synchronization issues
IPCBuffer subsystem can now set Clock Divider and sublayout Thread ID
Bug Fixes
Fixed issue when controlling WaveFileSink with another module
Fixed regression tests for Delay Reader modules
Fixed issue where Audio Start/Stop callbacks weren't being called on secondary instances
Fixed typo that affected building for 64-bit targets
Fixed issue where overflows on secondary instances could halt primary instance
2023-NOVEMBER-8
New Features
New FIR Reader module allows users to share state betwen multiple FIR filter modules
New GraphicEQFract32V2 module that adds frequency array to previous version
Enhancements
Updated AWE Core OS architecture to reduce audio dropouts during extended deferred processing
Controlling modules (ArraySet, ParamGet, ParamSet, ParamSetTableV2, StatusSetV2) can now specify when to execute relative to the module being controlled
Allow loading .awb's on non-multi-instance targets, even if the .awb instance ID does not align with the target's instance ID
Bug Fixes
Fixed an issue when loading Compiled Reusable Subsystems on multi-instance targets
2023-SEPTEMBER-18
New Features
Enhancements
Bug Fixes
2023-JULY-21
Enhancements
Bug Fixes
2023-JUNE-2
New Features
Enhancements
Bug Fixes
2023-FEBRUARY-15
New Features
Enhancements
Bug Fixes
2022-DECEMBER-05
New Features
Enhancements
Bug Fixes
2022-SEPTEMBER-21
New Features
Enhancements
Bug Fix
2022-July-21
Bug Fixes
2022-July-05
New Features
Enhancements
Bug Fixes
Fixed issue where unchecked
2022-MAY-12
New Feature
Enhancements
Bug Fixes
2022-APRIL-6
New Features
Enhancements
MATLAB
Bug Fixes
2022-JANUARY-7
New Features
Enhancements
Bug Fixes
Corrected
