AWE Core, AWE Core OS
AWECore 8.D.10, AWECoreOS 8.B.20
2024-DECEMBER-
New Features
Updated AWE Core multi-instance implementation to support Progressive Loading for Early Audio use cases
Added an API that can be called from modules to return the parent layout's index
New logging callbacks added in AWE Core to provide log messages to user application
New Event module can trigger new event callbacks on the target system
New AGCAttackHoldRelease implements a new AGC with additional control parameters
New PeriodicFuncGen module implements an efficient table-lookup based wave generator
New BufferSourceV2 modules add flexibility, including option to store the data as interleaved or deinterleaved buffer
New ParamSetV2 module adds support for variable mask in deferred set calls
New ActivationMux module can be used to safely control changing status of multiple subsystems
New MuteNSymmteric module adds per channel control to MuteSymmetric module
New RebufferedSink module combines a rebuffer module and a sink module, which can greatly reduce memory and CPU usage
Enhancements
Improved reliability and usability of WaveFileSink module
Updated ParamSetTableV2 to always rewrite values when the array is updated, even if index is unchanged
Added support for M55 targets that do not support Helium
Updated DelayMixerSmoothed module code to protect against negative delays
Improved performance of Router in certain configurations
Bug Fixes
Updated DelayStateWriter to fix potential issues in FIRReader modules
Fixed Biquad module to work with 12 or more channels
Fixed issue with AGCLimiterCoreV2 when saved in AWJ files
Fixed crash in FilterbankFIR modules that could happen if module failed during construction
Fixed potential memory leak when loading AWBs from file on Linux targets
Fixed issues with AWECoreOS tuning logging and packetBufferSize configuration option
Fixed SystemVariable module to get system information from current layout when appropriate
Updated BiquadLoading module to avoid potential small differences between input and output
Updated Subtract module to fail builds if input pin is not float
No longer overwriting internal parameter ranges for BiquadSparseV5/6 modules during prebuild
Fixed integer display issues in module .html documentation
Corrected reply length of PFID_FetchValue in Tuning Syntax documentation
Fixed issue with synchronization resets on multi-instance targets with > 2 instances with different base clock dividers
AWECore 8.D.9, AWECoreOS 8.B.19
2024-AUGUST-15
New Features
New Constant DC Source module that enables users to control module variables with Layout Arguments
Added support for Cortex-M55, SHARC-FX, and Kalimba targets
New AGC Core V2 Fract32 module that allows for more gain using Q8.24 output format
Added new
PFID_GetAllMatchingModulesfor returning the objectIDs of all modules in a layout that match the provided classID
Enhancements
Overflows are now measured per instance, and profiling corrects for time lost to preemption
Improved AWE Core Integration Guide with troubleshooting tips
Created new icons for the ChangeThread module
Bug Fixes
Fixed crash when checking the heaps on an invalid instance
Fixed issue in AWE_Server where heap usage would not appear when loading an AWB from flash memory
AWECore 8.D.8, AWECoreOS 8.B.18
2024-JUNE-10
New Features
New Conditional Replace module to deterministically replace the output with a constant value
New API function awe_getBuildVersionInfo returns library build and version information
New Change Thread module to buffer data to any specified target instance and/or thread
Enhancements
Updated Flash File System API functionality for valid pointers
Updated PFID_GetProfileValues' documentation for the correct datatype of the reply values
Updated documentation to clarify that Control API can only access the active core's instances
Updated documentation to clarify that Preemption API can be called by any instance shared by the same core
Bug Fixes
Fixed AWE_Server's Flash Manager tool to access multi-instance target files
Fixed regression test failure for WetDry, SecondOrderFilter, and SecondOrderFilterCascade modules
Improved reliability of CrossoverFilter module's regression test
Fixed issue where Mute Symmetric module could audio "pop" if driven by a Param Set in deferred update mode
Fixed Module System Test failure for Wave File Source modules
Fixed issue where FilterbankFIRNChan modules weren't calling destroy for internal FFT modules
Fixed issue when loading a layout on multi-instance targets that shared Packet and Reply buffer memory
AWECore 8.D.7, AWECoreOS 8.B.17
2024-MARCH-15
New Features
New Scaler Symmetric Fading V2 module that enables external control of the gain value
New ClipAsymInt32 module that performs Asymmetric Clipping for integer values
New PFID_GetProfileValuesPreCalc message to support consistent profiling across irregular pump calls
New AWE Core API Callbacks to capture audio interrupts for accurate profiling
Enhancements
AWE Core can now allocate memory aligned up to 128 words
Added support to run Module Regression Tests on Multi-Instance targets
Added Frequency Response functionality to Biquad Sparse V6 module
Allow users to adjust Compiled Reusable Subsystem parameters with ParamSet
Added optional support to control scalar values with ArraySet
Bug Fixes
Fixed crash when loading certain AWB files containing Flash-based Wave Player modules
Updated user documentation with more details on the SPI Tuning Protocol
Fixed issue when instantiating Compiled Reusable Subsystems that control variables in nested subsystems
Fixed default range of ClipAsymFract32 to (-1, 1)
Fixed issue in module documentation that incorrectly stated that gain filter type uses linear units
Fixed issue where BiquadLoading modules were using First Order implementations on some targets
Fixed regression test failures for the following modules:
BufferDownV2
BufferUpV2
CycleBurnerSet
MeasureSampleRate
MultichannelMixerSmoothed
SystemVariable
FileStreaming
AWECore 8.D.6, AWECoreOS 8.B.16
2024-JANUARY-26
New Features
Added support for QNX-based targets
New API that supports multirate processing on different instances
New 8 channel biquad VectorLib function for certain filter modules
Enhancements
Updated default channel names for some modules
Fixed issue with stale coefficients in subsystem by forcing recalculation during prebuild
Reduced the duration of certain module regression tests
Improved robustness of IPC buffers against multi-instance synchronization issues
IPCBuffer subsystem can now set Clock Divider and sublayout Thread ID
Bug Fixes
Fixed issue when controlling WaveFileSink with another module
Fixed regression tests for Delay Reader modules
Fixed issue where Audio Start/Stop callbacks weren't being called on secondary instances
Fixed typo that affected building for 64-bit targets
Fixed issue where overflows on secondary instances could halt primary instance
2023-NOVEMBER-8
New Features
New FIR Reader module allows users to share state betwen multiple FIR filter modules
New GraphicEQFract32V2 module that adds frequency array to previous version
Enhancements
Updated AWE Core OS architecture to reduce audio dropouts during extended deferred processing
Controlling modules (ArraySet, ParamGet, ParamSet, ParamSetTableV2, StatusSetV2) can now specify when to execute relative to the module being controlled
Allow loading .awb's on non-multi-instance targets, even if the .awb instance ID does not align with the target's instance ID
Bug Fixes
Fixed an issue when loading Compiled Reusable Subsystems on multi-instance targets
2023-SEPTEMBER-18
New Features
Enhancements
Bug Fixes
2023-JULY-21
Enhancements
Bug Fixes
2023-JUNE-2
New Features
Enhancements
Bug Fixes
2023-FEBRUARY-15
New Features
Enhancements
Bug Fixes
2022-DECEMBER-05
New Features
Enhancements
Bug Fixes
2022-SEPTEMBER-21
New Features
Enhancements
Bug Fix
2022-July-21
Bug Fixes
2022-July-05
New Features
Enhancements
Bug Fixes
Fixed issue where unchecked
2022-MAY-12
New Feature
Enhancements
Bug Fixes
2022-APRIL-6
New Features
Enhancements
MATLAB
Bug Fixes
2022-JANUARY-7
New Features
Enhancements
Bug Fixes
Corrected
