AWE Core, AWE Core OS
2023-NOVEMBER-8
New Features
New FIR Reader module allows users to share state betwen multiple FIR filter modules
New GraphicEQFract32V2 module that adds frequency array to previous version
Enhancements
Updated AWE Core OS architecture to reduce audio dropouts during extended deferred processing
Controlling modules (ArraySet, ParamGet, ParamSet, ParamSetTableV2, StatusSetV2) can now specify when to execute relative to the module being controlled
Allow loading .awb's on non-multi-instance targets, even if the .awb instance ID does not align with the target's instance ID
Bug Fixes
Fixed an issue when loading Compiled Reusable Subsystems on multi-instance targets
2023-SEPTEMBER-18
New Features
Enhancements
Bug Fixes
2023-JULY-21
Enhancements
Bug Fixes
2023-JUNE-2
New Features
Enhancements
Bug Fixes
2023-FEBRUARY-15
New Features
Enhancements
Bug Fixes
2022-DECEMBER-05
New Features
Enhancements
Bug Fixes
2022-SEPTEMBER-21
New Features
Enhancements
Bug Fix
2022-July-21
Bug Fixes
2022-July-05
New Features
Enhancements
Bug Fixes
Fixed issue where unchecked
2022-MAY-12
New Feature
Enhancements
Bug Fixes
2022-APRIL-6
New Features
Enhancements
MATLAB
Bug Fixes
2022-JANUARY-7
New Features
Enhancements
Bug Fixes
Corrected
